Old 04-23-2016, 09:54 AM
NYTOM NYTOM is offline
Red face Your Compass mounting experiences
Looking for input on mounting a whiskey compass on a slider. Has anyone found it impossible with the steel rollbar and center brace causing interference?
I'm getting directional info from two other electronic sources but just like the idea of having a old school compass available. Anyone? Bueller? Bueller?
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
Old 04-23-2016, 10:40 AM
terrye terrye is offline
Default Sirs Compass
I bought the SIRS compass and roll bar brace mount from Vans. I've grown to like it even though I initially preferred the look of Airpath. Was unable to find or make a good mount for the Airpath.
Not flying yet so this doesn't help you much. But my roll bar brace from Vans is non-magnetic stainless steel.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
Old 04-23-2016, 11:23 AM
Robin8er Robin8er is offline
Are you talking about interferance from the roll bar? Im not at that point in the build yet, but I'm pretty sure you have to degauss the roll bar.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 04-23-2016, 11:33 AM
Bevan Bevan is offline
I tried to degausse the roll bar but was unsuccessful. I eventually found an acceptable location in the lower middle panel as I had to avoid the welds at the sides and the center top where the brace attaches. I rarely use the compass and rely on the EFIS's digital magnetometer located out in the wing tip.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 04-23-2016, 12:14 PM
N941WR's Avatar
N941WR N941WR is offline
I didn't bother with a compass on my plane because one is included in the EFIS.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-23-2016, 02:59 PM
Steve Steve is offline
I've the SIRS compass mounted on the roll bar brace. Heads up - if you use a tablet app for nav, the tablet's battery will cause the compass to swing a few degrees, unless the tablet is located to the far sides of the cabin or on your thigh, kneeboard style.
Five Sierra Fox
RV-9A
Utah
Old 04-23-2016, 06:44 PM
Thanks for all the help. I was afraid that was going to be the case. Probably never use it anyway. Guess I'll save the weight.
Tom Norwood
TMX-O360. Phase 1
Old 04-24-2016, 04:55 AM
n816kc n816kc is offline
Default -6 slider SIRS
I moved a vertical card compass to several different locations in the panel without finding a spot where it worked to my satisfaction. SIRS on the roll bar brace works great.
Kevin Crews
Bartow, FL
RV-6 'Woo hoo!'
2019 =VAF= donor
Old 04-24-2016, 06:46 AM
MikeyDale's Avatar
I'm with Bill, two effis screens, 1 or 2 cell phones, and a handheld compass in the side pocket for emergency that I have not used yet is enough for me!
Mike Hillger
RV 7 FLYING SINCE 4/2015!
Garden City, Texas
Dues Paid
Old 04-24-2016, 06:55 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
I had the local FAA FSDO office sign off my RV-10 four years ago. The inspector required a TSO compass in the plane - even though I had two independent EFIS ADHARS units.
No - this is not a requirement that I could find, but such was the cost of getting the plane signed off. Perhaps old thought such as this is working its way out of the FAA.
Carl
