Old 04-20-2016, 04:40 PM
Bevan Bevan is offline
Default Where to aim landing lights?
To illuminate the runway when on the approach or in the flare? or one each?Two very different angles for focused beams.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 04-20-2016, 05:25 PM
My opinion:
In my -10 I set both lights to optimize lighting when taxiing. I have been to enough airports with unlit taxiways - and the stock lighting is so marginal - that I need lights to avoid running off the taxiiway, or into parked cars or even airplanes. OTOH I do not fly into unlit runways at night, in which case lights are not needed and, due to their limited range, sometimes make for poor landings.
ymmv
Old 04-22-2016, 10:27 AM
ExtraKatana's Avatar
ExtraKatana ExtraKatana is offline
ON my 6A, I had one pointed slightly low for taxiing and the other to illuminate the runway enough to be comfortable just before the flare. I wanted to make sure there was not a deer etc within the next 75 Yds or so.
Old 04-22-2016, 01:10 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Auto headlights on my -6A
"Bob Olds" style auto headlights ---- high and low beam ---- very handy! Switch "up" for high beam, switch "down" for low beam, and center "off".
R.
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
