04-20-2016, 03:39 PM
Landing light location verses taxi
Any preference on which wing the landing light goes into ? One per wing, taxi will go into the other.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
04-20-2016, 04:24 PM
I had asked the same question and I went with taxi on left and landing on right.
Anthony
RV6-A "Aluminum Mistress"
Too many hobbies- not enough time.
2016, 2017, 2018, 2019 donor and happy to do it.
04-20-2016, 04:27 PM
Although I went through the same process, I rarely if ever have just the taxi light on. Both are on or both are off - I just don't really have much of an occasion for a "taxi light only" situation.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
04-20-2016, 04:30 PM
Is this more of an issue for non 'A' models, especially with taxi lights ?
04-20-2016, 04:56 PM
I use low beam left light for taxi, both high beams for landing.
My reasoning is that low beam directs the beam down and to the right.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
04-20-2016, 05:48 PM
Taxi on the left it is. Thanks Guys.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
04-20-2016, 09:26 PM
Yes.
A light aimed for use as a landing light wont light up much of the taxiway on a tail dragger. One can be aimed as a taxi light and the other as a landing light (then it also keeps the runway lit up during the round-out and flare during landing).
It also is bad manners to taxi around pointing at other aircraft at night with a landing light aimed directly into their cockpits. This is a good reason to have them aimed differently.
On a tri gear it is not quite as important, but something like a 6A that sits rather nose high it is still a good idea. I have the lights on my 6A set up this way.
Scott McDaniels
Hubbard, Oregon
04-20-2016, 10:13 PM
I get asked this question a lot. And it really only matters on the side by side models where the taxi light makes more sense on your flying side. The Whelen taxi light models have a very wide beam that lights up everything in front of you while taxiing.
Kahuna
6A, S8 ,
Gold Hill, NC25
