04-25-2016, 03:18 AM
Now I can report that the stiffeners I have recently fitted do eliminate the shimmy I previously encountered on hard-surface runways.
Maybe now I can safely increase my 24 psi tire pressure a bit.
I'm planning to inspect the stiffeners closely at the end of the summer season and see whether the cable ties (apart from ones where I used rubber backing) have marked the legs, loosened or deteriorated in any way.
04-25-2016, 09:32 AM
Good to hear that the stiffeners worked for you. I haven't balanced any of my wheels/tires and run pressures of 40 psi all around. I've heard stories of people blowing tubes up front as a result of too little pressure. Make sure that the break-out force is within spec!
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
04-25-2016, 11:19 AM
A friend ripped the valves off his RV7's tubes due to running low pressures and braking too enthusiastically .......
04-25-2016, 11:30 AM
Originally Posted by lr172
I understand the logic and rationale for this recommendation. In my case, I chose tie wraps as I was concerned about corrosion under the F/G wrapping. My experience has been to avoid creating situations where moisture will be kept in contact with steel when possible to minimize corrosion. I found several posts from other members finding corrosion similar to what Katie found. The stiffener is not structural and therefore I was not concerned if the tie wraps failed. I used a rubber buffer to eliminate chafing.
Larry
What exactly did you use for the "rubber buffer"? Silicon self fusing tape or something else?
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
04-25-2016, 11:33 AM
So - what exactly did you use for a rubber backing? (Seems like I am conducting a survey about rubber backing now  )
Dan Langhout
04-25-2016, 01:41 PM
For my backing, on some of the cable ties, I used a piece of bicycle tube rubber.
04-25-2016, 07:41 PM
proseal
The steel gear legs are rust prone by nature of alloy. I chose a slightly different approach, and epoxy primed, urethane pained the legs, then set/bonded the wood stiffeners with Proseal and taped in place. After Proseal cured, I wrapped with 3 layers of glass and sealed top and bottom with Proseal. 5 years in service, no cracks, corrosion and no shimmy. I don't recommend any RTV around steel, as it's acid will cause corrosion.
Bill E.
RV-4/N76WE
8A7 / Advance NC
04-25-2016, 09:44 PM
It is a rubber tape that comes on a roll for electrical. It is not really self- fusing, but it does kind of stick to itself. It is maybe 1/16" thick. Get it at home depot
04-26-2016, 07:23 AM
Thanks . . . .
. . . . for the info.
Dan Langhout
04-26-2016, 07:35 AM
Can you please expand on the statement about steel and RTV? I have been using this stuff on steel, cast iron, aluminum engine, TC, and diff parts for decades......
