Old 04-17-2016, 06:07 PM
blueflyer's Avatar
blueflyer blueflyer is offline
Default Will this Marker Beacon work by itself?
I picked up an RST Engineering Audio panel/marker beacon, and I have read the users manual, but I still cant answer my question, so maybe somebody here knows. Will the marker beacon work without being connected to the audio panel?
I want to connect the marker beacon light wires straight to my D100 marker beacon "receive" wires, provide power and ground to the unit, and connect the MB antenna. Will that work?
Old 04-17-2016, 06:36 PM
Mich48041 Mich48041 is offline
Is THIS PDF for your marker beacon? If so, it looks like it will work without the audio output connected.
But compatibility of the light output with other units is unknown.
(Ground is switched)
Joe Gores
RV-12 Flying
Old 04-17-2016, 07:26 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Safest thing would be to connect a 10K resistor to 12v on each MB light output pin.
The pins (5,6 & 7) would then become voltage inputs to the D-180 -
12v = off
0v = on
Audio appears to be available on Pin 4 of the MB, but that would have to be an aux. input to your existing audio system.
UPDATE
You may have this unit with the built-in lights.
If this is the case - check the RST part numbers on the box label - then the 10K resistors are not needed and the pin numbers give above change to 6, 7 & 8.
http://www.rst-engr.com/rst/support/RST-522_523.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-18-2016, 10:46 AM
blueflyer's Avatar
I think it will work, thank you both. I originally did not see the test procedure listed in the pdf that Gil sent. I will go out soon and try this. Now I gotta get out there and locate that marker beacon on the top of the building somewhere off the end of the runway! Thanks again.
Old 04-19-2016, 07:45 PM
n82rb's Avatar
n82rb n82rb is offline
Jim posts on pilots of America you can leave a post for him there.
Bob burns
Rv-4 n82rb
