Old 12-25-2006, 10:04 AM
George in Langley BC George in Langley BC is offline
Default WHATS WRONG WITH USING VELCRO?
Hi Builders
I am just starting on the gear leg fairings on my 7A and as I was laying in bed thinking about the trailing edge hinges the question popped into my head, whats wrong with using Velcro?
Advantages are lighter and simpler, only worry is how long the Velcro glue will stay attached to the epoxy fairing.
Anyone have any comments on how well industrial quality Velcro will stay attached in a very small load application??
George McNutt / Langley BC / 6A Sold / 7A Flying.
Old 12-25-2006, 10:16 AM
vlittle's Avatar
vlittle vlittle is offline
Originally Posted by George in Langley BC
Hi Builders
Hey George... too exicted about Santa arriving?
Here's the stuff you need 3M Dual Lock. They even offer types that can be riveted in place.
The only limitation is the lower temperature limit. You'll need to pore through the datasheet to see if this applies in the static application, or only applies if you are pulling them apart.
Merry Christmas, Chocks!
Vern
Old 12-25-2006, 10:37 AM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Dimensions
Maybe you have thought this through, but it seems to me that it would be much harder to find the exact position for the velcro that will bring the trailing edges of the leg fairings snugly together and still not put too much pressure on the velcro. It will surely be lighter! I would like to know how this works out, too. Thanks.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 12-25-2006, 04:46 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Flexing
I think the biggest issue would be the velcro or the other stuff mentioned, will not provide the necessary stiffness to the trailing edge of the fairing. You don't want the fairing flexing or you'll never be in trim. The hinge system is quite quick to build and very efficient.
The 3M stuff mentioned has incredible grabbing power. So much so I think you might have trouble getting the thing undone!!!
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 12-25-2006, 06:32 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default No, bad idea, why?
OK someone has to say it. Lets stop beating around the bush. No. Bad idea. Why?
"Build it per plans"
If you follow the mantra, "Build it per plans", chance is you will fly sooner, lighter, cheaper and it work well. The piano hinge or bonding it on perminatly is the time honored tradition.
Go it alone, chance is you'll add time, cost and problems.
You really don't need a removable gear leg faring any way. How many times has the gear leg fairing come off in 1000 hours? zero.
I'm going to guess velco is not cheap. Also you want to have the gear leg TE's locked in postion, both edges flush and aligned. If it comes undone it could cause some grief and vibration. No. Bad idea. Why? Sorry someone had to say it.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 12-25-2006, 07:48 PM
KTM520guy's Avatar
KTM520guy KTM520guy is offline
Don't be like the herd, walk your own path.
RV-8A builder
A&P mechanic
Aviation Plasticized Pigmented Polymer Application Engineer
Old 12-25-2006, 08:01 PM
Default Um-mm wildebeest
Ha ha ha, well normally I'd agree, but in aviation walking your own path is like the lone straggler wildebeest / antelope in the herd, it gets eaten by the lion. What kind of dent would the gear leg fairing make in the tail?
George
Raleigh, NC Area
2020 Dues Paid
Old 12-25-2006, 11:50 PM
KTM520guy's Avatar
The original poster gets a "A" from me for thinking outside the box. Myself, I'll use the piano hinge even though I hate that stuff. I don't think velcro would be totaly bad. If you use upper and lower fairings,they will hold the gear leg fairing in place. Don't forget, a lot of times there is a hose clamp at the top of the fairing. I'm pretty sure it's not going anywhere.
RV-8A builder
A&P mechanic
Old 12-28-2006, 10:29 AM
kentb's Avatar
kentb kentb is offline
The fiberglass under my hose clamp broke the first flight it made.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 12-28-2006, 03:04 PM
Dgamble's Avatar
Dgamble Dgamble is offline
Kent
I'm working on that part right now. Did you lay any additional glass under the fiberglass tab?
Dave Gamble
Grove City, OH
RV-6 N466PG Purchased already flying - SOLD!
The Book: The PapaGolf Chronicles
Built RV-12
http://www.schmetterlingaviation.com
The Book: Being written.
The above web blogs and any links provided thereto are not instructional or advisory in nature. They merely seek to share my experiences in building and flying Van's RV airplanes.
