Go Back   VAF Forums > The Never Ending Debate Section > Primers
  #21
Old 05-30-2016, 11:17 PM
mbishop mbishop is offline
How are you spraying this inside?
You've been hitting all my questions right before I needed to post it, btw
Working on the fuse (RV-10).
Old 05-31-2016, 04:16 AM
LuisR LuisR is offline
No, not spraying inside. Plan is to spray outside.
Regards
Luis
---------------------------RV-10---------------------------
Empennage. Complete Minus fiberglass and attach section. FOR SALE
Build Log N925LC (Reserved) YouTube
Old 05-31-2016, 05:28 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Default For when I need to spray inside
(colder wx) I'm planning to build a collapsible downdraft spray booth/table using an 8" Harbor Freight cylindrical fan for the air handling to duct the fumes under the garage door. I'll be sure to put pictures here when it's done. Already assembling parts.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
Old 05-31-2016, 06:41 AM
Originally Posted by wirejock View Post
HF sells disposable filters for water and oil. They last quite a while and work pretty well. I use one at the gun.
As far as a regulator at the gun, I recommend it. You want stable pressure at the gun. I prefer a good one like MicroAir. The HF varied enough to cause problems with consistency.
Of course that's my $.02. YMMV
I saw those at HF when I picked up the gun. Since it was "HF", I didn't think it would work well. I'll give it a shot, and see how it does. When you say "awhile" how long is that? One session, an entire empennage?
Not sure if water will be an issue with spraying AKZO in FL, how do I know if water in the air is an issue. First time spraying with a HVLP.
Regards
Luis
Old 05-31-2016, 07:41 AM
wirejock's Avatar
wirejock wirejock is offline
Default Water
The filter longevity will depend on so many variables. Im guessing several sessions if you have a water/oil filter at the compressor supply line. In Florida, check it after each session. There shouldn't be any water droplets on the gun side. I keep mine on the hose side of the gun. Hose connects to the filter then regulator then gun. There's a photo of my paint gun on my blog.
Water in the air will look like little pinhead size imperfections in the paint surface. They are called fisheyes.
If humidity becomes a problem, run a hose to a small condensation tank then to the gun.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 05-31-2016, 08:14 AM
I don't have any filters at the compresor. Was going to get one but instead posted here for advise. I did a quick amazon search for compressor dryer and too big a selection turn up. Recommendation woukd be great here.
Regards
Luis
Old 05-31-2016, 09:13 AM
wirejock's Avatar
Default Air/oil separator
Something like this will work. Look for similar air/oil separtors at the big box stores. Plumb it into the line as close to the compressor supply as possible. Drain both the tank and separator daily.
http://www.amazon.com/gp/aw/d/B0186I...2QAPV7QFZCYAMM
Larry Larson
Estes Park, CO
Disclaimer
Old 05-31-2016, 10:54 AM
Thank for the link. I see they vary in size. Does bigger mean better filtration? The big biz stores carry one about 2-3".
Regards
Luis
Old 05-31-2016, 12:42 PM
wirejock's Avatar
Default Separator
I'm no expert but my gut says yes. Mine is about 6-9" tall.
You want one with a simple to operate valve at the bottom to purge the condensate regularly.
Mine has a rubber valve. A little tug in any direction opens it.
For priming, it's probably not a big deal. For finish paint work, humidity is bad joo joo.
Larry Larson
Estes Park, CO
Disclaimer
Old 05-31-2016, 02:27 PM
MJarreau MJarreau is offline
Default Rick Galati
Rick (Rick6a) responded to a similar post in mid January 2011 that went into a number of issues. I tried to find the exact post but ran out of time. Perhaps someone else will have the link.
Good luck.
Michael
DUES REMINDER: JAN 2021
