Old 04-13-2016, 11:02 PM
jnmeade jnmeade is offline
I have in-floor heat in my 36X48X16 shop in Iowa. My boiler is a little on the small side and in a bad spell it doesn't stay warm enough to be comfortable. A bigger boiler might fix it. I'm toying with the idea of adding some radiant heat to address bitter cold spells and for rapid recovery. If the door is open and closed several times on a cold day it can take a while to warm up again.
The in-floor heat is very nice. It might be more expensive than radiant. When I put it in it was the way to go. Now, I'd have to look harder at radiant.
Others have pointed out that insulation and tightness if critical. I have a Hi-Fold door on one end that will seal tightly (except for the bottom corners, but that is my fault). The overhead door on the north end is more drafty and sometimes I stuff the cracks when the wind blows against it.
I have not felt the need for a fan, but respect the opinion of those who have them.
No drafts means I leave my thermostat at about 55-60 allyear round. It's very comfortable and it's nice to work on a floor that is warm.
My own preference is to avoid the forced air furnaces as I think they add a draft that requries a higher heat setting for the same amount of comfort.
My in-floor is run from a conventional LP water heater.
My teen-age girls and I installed the Pex heating tubes.
Tubes in the floor means you can not just drill a hole and install an anchor. I once drilled into a floor a nicked a line. I had to chisel the concrete out, cut the tube and install a connector. It was a nuisance but it has held ever since.
If you ever have a notion to install a jib crane or a car jack, it would be good to installthe footings for them before running the Pex as it's pretty hard to do that after the line is laid.
In my opinion, a radiant heater is more flexible when it comes to modifying the floor in any way.
The in-floor heat needs to be laid out by someone competent. I wish I had taken pictures of the lay-out with some reference stakes so I could measure to where a line was - that would let me drill into the floor with more assurance. I thought of using a heat sensor to locate the lines but haven't explored that - I suspect it might be hard.
I wish I hard run my in-floor heat just outside the doors a foot or so to be sure they didn't freeze down.
Sub-floor insulation and some kind of vapor barrier is important for in-floor heat. A good footing or rat barrier is useful, as the rodents otherwise will tunnel under that nice warm floor.
My bottom line - I think I'd investigate radiant heat now. Will need to be careful to not place it directly over something that doesn't take higher temperatures well. My farm shop gets the doors opened regularly so recovery time may be more important than for a hangar, and my boiler is a little small so recovery or added heat in bitter weather may be more of an issue to me than if the system were sized right.
FYI, I run pure water. The concrete acts as a heat sink so if I lose power or run out of LP I won't freeze up instantly. I'd not like to leave it alone for a week in a blizzard with a power failure.
My insulation is 6" bat in the walls and 12" blown in the ceiling. Foam would be better. Door insulation is critical, as most doors are thin. Doors have max loads so you can't add unlimited weight.
These are just my observations.
Old 04-14-2016, 05:30 AM
BillL BillL is offline
Originally Posted by bpattonsoa View Post
We built our house at Independence Airpark four years ago. It has a gas commercial furnace hanging in one corner.
How you heat it is not as important as how you insulate and seal it. Our hanger is attached to the house and insulated to the same standards as the house, I.e., R-38 in the ceiling and R-21 in the walls. The windows are same Eglass double pane as the house. The slab should have edge insulation, but it is not critical in a 44' X 50' 16' high hanger. There are four ceiling fans that have not been shut off since we occupied the house. They keep the hot air mixed and not all up top.
The doors are a problem. There is a large insulated RV door. The Hanger door is covered with R-11 foam board. Keeping it tight is a problem. Pay careful attention to how the top is made airtight, a flexible fabric attached to the door frame and the hanger works best, but it is not a standardized thing.
A heated floor would be nice in the winter.
At my last working job, we had a huge shop for heavy equipment. Designed for 365 day use down to -20F. The doors could not be fully insulated, so the design used a pleated drop insulation from the top. There was a gap of about 1-2 feet to the door. At -15F it really worked well. No heat in the floor due to need to support a D11, 785 truck, etc.
Here in central ill - I got a ground source heat pump, and it is fantastic. My home is super insulated, but the GS still cut my electric bill nearly in half, just in time for a 100% increase in $/kr-hr hike (for wind farms). Earth supply temperature is 60F all year. GS might be a cost effective option for the long term, NG is not available for me. Floor heat (hydronic) sounds comfortable for work.
Bill
RV-7
Lord Kelvin:
Old 04-14-2016, 09:17 AM
flyboy1963's Avatar
Default suuuuuuuuuuuuuuch a problem!!!!
Mark, much as most of us just hate you for having a 55'x 50 hangar.....I have to put in my $.02 a couple ideas nobody has forwarded.
because it's so big, I have to ask.....how many places can you stand, or work, at once?
Perhaps just heated boots?
I have a 3 car garage, but I work in front of the bench 99% of the time. So a $60 radiant heater sitting on the floor warms me up in about 5 minutes. by lunchtime, the bench, tools etc. are all warm to the touch. Radiant kicks butt.
Your 'contractor' should be put in that special place where they put people who suggest what's quick, easy, and cheap...for them. They don't have to live with the result. Big hanging forced air units are 1940's tech, and they were stupid then too!..... good for wasting a LOT of energy ( $$$) and heating the air at the ceiling. Sure, fans can push it down a bit ( more $$$ to run) but the draft is uncomfortable.
Look at the big hangars, like Buffalo Airways in the faaaaaaar north, ( Yellowknife etc.) they have black pipe radiant tubes overhead. It warms the planes, then the floor, then the air.
If you have a 'tool zone' you could put a wooden subfloor in the area only, or even build up a platform, 3" thick, insulate it, and put radiant floor panels in it.
.....hang a clear poly curtain/ceiling enclosure, and you'll have a shirtsleeve environment for a few bucks an hour.
If you have the choice, and budget, radiant first, for quick heat, then slab heat, but put in a LOT of zones, so you can mitigate leaks, and only heat the area you are using. You need good thermal breaks at the outside walls and under doors etc....or you lose all that nice slab heat to the outside....unless you WANT to melt the snow on your ramp!?!?? Beats shoveling! ( wait, tell the wife you need a 4-wheel drive tractor too, with a blade, and backhoe, with mower, and a cab, with a towbar, and a/c with MP3 surround-sound, ......ah heck, you probably already have one eh???
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 04-14-2016, 01:35 PM
s10sakota's Avatar
s10sakota s10sakota is offline
Well let's not get excited yet-55x50 is my initial plan that is being drawn up. Once I get the price from the builder I may have to make it 10x10 LOL...
Forced air is definitely out as it is too inefficient. Heated floors or the tube radiant heat sounds like the way to go and so far I'm leaning towards heated floors.
Mark Pensenstadler
1962 Piper Cherokee 160
2003 RANS S-10
2011 RANS S-6S
2011 Vans RV-7
2015 Zenith Cruzer
1962 Mooney M20C
2019 KITFOX Super Sport
Old 04-18-2016, 05:55 AM
Bud K's Avatar
Bud K Bud K is offline
Default Heated Floor
My nephew is building a house in Southern Indiana and plans to use an outdoor woodstove to heat the floor in his basement and garage. He already has one in his apartment in his pole barn and swears by it. All he has to do is keep the outdoor wood stove fired up. We have a electric heated tile floor in our bathroom and love it.
Bud K
N682TT RV-7
Legal Eagle - Flying
FFR Roadster (sold)
Old 05-10-2016, 09:32 PM
sgubser sgubser is offline
Default Heating
Either forced air gas furnace or heated floors circulating hot water heated by a gas boiler. Natural Gas prices will be you lowest cost heating for the next two decades at least.
Steve Gubser
Houston, Texas
Old 05-11-2016, 04:57 AM
bobnoffs bobnoffs is offline
Default in floor heat
insulation is mentioned but i want to stress the insulation under the floor.direct contact with the ground will suck the heat out like a tongue on a cold flagpole. get good advice on how much styrofoam under the floor.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
