Originally Posted by x55pilot
Has anyone changed their Tip Up canopy to a Slider? If so what are the issues to convert to a slider, is there and easy way to come up with a parts list.
I do not work for Van's so the info may only be worth what you are paying me for it.
Looking at the RV-6 drawings, it should not be a difficult issue to convert from Tip Up to Slider canopy. There is extra structure in the fuselage for the tip up. Switching canopies, the extra structure will be left in the fuselage. The slider has two stiffeners added in the skin behind the canopy in the baggage compartment. IF the skin on the slider is large enough, one may be able to add the stiffeners. The bulkhead / ribs in front of the panel are different as is the skin over them. It is not going to be a fast job but if you built a standard build RV-6, it should not be beyond your abilities.
I am typing this from memory. IF I were going to do this, I would get all the drawings, study the differences, then make my decision.
