Old 04-12-2016, 12:00 PM
Kato's 8 Kato's 8 is offline
Default Vinyl tubing master supply lines
This question is regarding the supply lines from brake resivoir to the low pressure end of the master cylinders. On my rv8, I used the nylon t fitting at resivoir and then the nylon type supply lines down to the masters where the connection were with a brass fitting with collar. Has been working fine for last year. While bleeding my lines on a Citabria I notice that my A&p fixed my leaking brakes with simple Black barbed T's and what looks to be vinly tubing (clear flex tube). Simple zip ties on each end of the vinyl supply line to the barb fittings. Now since this is a certified aircraft, How is this legal for starters? Second, will vinyl hold up to the brake fluid? It seems weird to me but then why wouldnt vinyl tubing work?
Bill
RV-8 QB Started Feb 2011
1510 hours build time as of March 2014
http://www.mykitlog.com/katocriss/
Old 04-12-2016, 12:29 PM
n82rb's Avatar
n82rb n82rb is offline
its not legal on a certificated aircraft, they have to be replaced with the part required in the parts manual ,or fabricated with like parts using acceptable methods. a zip tie on a brake line is NOT acceptable.
clear vinyl hose will rapidly harden when exposed to 5606. I have to replace the clear vinyl hose i use on my pressure bleeder ever year or it gets to hard to use it.
bob burns
Rv-4 N82RB
Old 04-12-2016, 12:42 PM
az_gila's Avatar
az_gila az_gila is offline
Question Tygon
Hopefully your mechanic used clear Tygon tubing, not vinyl, which is rated as "Fair" for hydraulic oils.
http://www.processsystems.saint-goba...p-Tygon(1).pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-12-2016, 12:48 PM
Gil, Thanks. I guess it could be a clear tygon. Im just floored that a certified a&P did this and that a separate AI signed it off during that anual inspection.
Bill
