PMag Tach signal erratic
New installation.
All is normal with RPM till I apply take-off power. I get >3000 RPM. Engine is definitely behaving normally as before the PMag install. After reaching cruise, the indication settles down with an occasional blip while actual engine rpm remains unchanged.
I am reading the signal through a AFS-5500 unit. Double checked the wiring and pin-outs. All good.
initial wiring, I ran two #20 wires to the AFS unit, signal and ground. Second attempt, I ran a shielded wire to the AFS unit. No difference. Tomorrow, I am going to swap to the right PMag to see if the issues follows.
Anybody else dealt with this issue? I will put a call into EMagAir tomorrow morning.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
