04-10-2016, 09:53 AM
We interupt this build
Finally, success at setting a 470AD4 rivet. 3 in a row.
Yesterday's session was miserable. I couldn't set a 470AD4 rivet for anything. Tried driving with my 3x gun at different air flows. Have the import brass flow control on the gun, so I'm not sure what my pressure is, but tried several different settings. Think I'm a little low now as it takes 2-3 seconds for an 470AD4-6. My big problem was smileys, both on the rivet and on the piece I was shooting. I suspect that I don't have enough experience and am not keeping adequate pressure on the gun. Not sure how secure things need to be, so I may not have my piece clamped well enough and it is possibly moving slightly.
I quit building and went out flying instead. Same result when I came home, so I quit early.
Using a squeezer eliminated smileys on the rivet, but was getting them on the spar doubler that I was riveting. Figured out that as I was squeezing I was slightly dropping the handle, causing the set to mar the piece. Looking at the shop head confirmed it. It was not truly flat, but raised on one side slightly.
Tried again this morning. By concentrating on not dropping the handle of the squeezer I was able to squeeze 3 acceptable, safe and good looking rivets in a row.
BTW, I read a thread last night about shooting 470 rivets several times over so I know I'm not the only one with this malady. Now, back to the shop.
Jeff Dingbaum
RV-14A empennage, wings, fuselage
Cherokee 180
2020 dues paid
04-10-2016, 10:13 AM
The trick to eliminate smiley when driving round head rivets is to put two layers of masking tape over the rivet set. The tape will last for 2-3 rivets - replace as needed.
For flush rivets put a piece of clear packaging tape over the set. The tape will last for 30 or so rivets. Replace as needed.
Get rid of the reducer at the gun and get one with a gauge on it. That way you can find the right pressure and be able to dial it in when found. This Harbor Freight reducer put together three airplanes so far: http://www.harborfreight.com/air-too...tor-68247.html
A 3X gun will work, but for 99% of RV riveting a 2X gun is better. Start with 30-35 PSIG for 3/32 rivets, 40-45 PSIG for 1/8" rivets. Adjust as needed.
Always run the squeezer at full pressure (100-120 PSIG). Keep it level and the set centered on the shop end of the rivet. If you need, get a smaller yoke (helps the balance). I have one deep throat and one shallow throat.
Carl
04-10-2016, 11:39 AM
You know what they say around here, if there are no pics, It didn't happen ;-)
04-10-2016, 11:52 AM
Gorilla tape
Just another tip.
Gorilla tape works great for universal rivet heads. A piece about 1" square is good for four rivets.
I prefer my Sioux 3X set to 30 psi for #4s.
Heavy packing tape works well for flush rivets. One piece with the edge folded over is good for lots of rivets.
I prefer to put the tape on the rivet instead of the set.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
04-10-2016, 01:54 PM
In Canada we use hockey tape. Ya I know - no Cdn teams in the playoffs.
Dennis Enns
Kingsville, ON
Bellanca Champ 7ACA since 1986, restored 1990.
RV-8 IO375, Hartzell CS, dual PMags.
2020 Donation In
04-10-2016, 02:13 PM
You used up all their tape!
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
04-10-2016, 02:34 PM
+1 for tape
I found It was easier to tape over the factory head. More tape was used but much better results. I also found higher PSI worked better. Less hits on the head, less time to have the gun move. I Use 50-60 PSI for 1/8 inch rivets
I also agree on clear packing tape for flush rivets.
On the other side, I tape up the bucking bar so it will not mar any internal stuff
Michael
Builders Blog http://elstien.us/wordpress/
RV-10 Builder
Tail Kit delivered 6-2013
Finished QB wings on September 2018
Moved to Port Orange Florida November 2018
Tailcone mounted to Fuselage on 3-1-2020
Finished Fuselage April / May 2020
Working working working on Doors
Engine Ordered (BPA/Fly-EFII 8/1/2020
Dues Paid through 2020
04-10-2016, 02:44 PM
I have the air line from my compressor routed into a y air fitting. One of those outputs I leave at the full pressure for my die grinder or air drill. The other output I have for reduced pressure for my rivet gun. I have the HF gauge / valve in that line. I also use the fittings and light weight hoses from Cleaveland Tools on those outputs. They are very helpful but not required. I put a wrap of red electrical tape on the high pressure hose so I can quickly tell them apart. This system seems to work well.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
04-10-2016, 04:45 PM
Getting Better
Thanks everyone, for the suggestions. I've gotten substantially better squeezing them and can get a nice looking rivet without smileys most of the time without tape. I plan on trying out the tape as insurance.
Now I'm just debating with myself over whether to order a new spar and doubler and redo them or keep moving. The smileys are all on the doubler piece. It's a pretty beefy piece and it should be ok structurally. Maybe I'll just leave it and call it my happy piece. I do have two holes that I buggered up removing rivets, so I'll need to order the oops rivets. One of them is slightly elongated so I'm not sure that an oops rivet will work there. Guess I'll send Vans a pic and see what they say.
Learning new skills is fun and sometimes it takes a while to get good at them. I guess that's what experimental is all about. I'm just getting started and I'm sure this will all seem silly to me eventually.
Jeff Dingbaum
Cherokee 180
2020 dues paid
04-10-2016, 06:39 PM
As you suggested, 3 seconds is too long to set a rivet. Up the pressure.
Practice on scrap. I like a long one second.
