Go Back   VAF Forums > Main > Safety
  #11
Old 04-10-2016, 02:31 PM
rapid_ascent rapid_ascent is offline
Lacquer thinner seems to work on most items so I only use MEK for a few things. MEK is a great solvent but a nasty chemical. I typically use HF Nirile gloves and MEK destroys those very quickly. Even Lacquer thinner will eventually break them down but generally they seem to work well enough.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 04-11-2016, 10:37 AM
joedallas's Avatar
joedallas joedallas is offline
Default MEK
All
It has been a week and I am still sick
MEK will not be used in my shop again
I hope no permanent damage has occurred
After all I am building a aircraft so you know I am not playing with
a full deck as it is.
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 04-11-2016, 10:46 AM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
We all knew that, but it is good to hear you finally admit it
Originally Posted by joedallas View Post
All
Joe Dallas
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 04-11-2016, 10:59 AM
The best part about completing building is I had an airplane. The second-best part is I don't have to use MEK anymore.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 04-11-2016, 11:11 AM
Brantel's Avatar
Brantel Brantel is offline
MEK is nasty but so is Acetone and Lacquer Thinner and many more solvents.
Use proper PPE with all of these chemicals......
Bottom line is all of this stuff can harm you if you don't use the correct PPE. Don't fall for the trap that some are dangerous and some are not.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 04-11-2016, 12:43 PM
DaleB's Avatar
DaleB DaleB is offline
Brian is absolutely right. Maybe you've never used PPE when working with solvents before, but you've probably never used them in this kind of quantity and frequency before either. I know I used more MEK in two years of building than I used in the preceding twenty.
I've been using various solvents since I was a little kid. Dad and I built a lot of model airplanes, and I still love the smell of butyrate dope. In the late 70s and 80s I worked with some pretty nasty stuff while working on mainframe computers... we'd regularly use Trichlorotrifluoroethane for cleaning and degreasing. No one ever thought to take any protective measures other than leaving the room before you passed out. Heaven only knows how much long term damage I and my former coworkers will be dealing with as a result.
We're older and hopefully wiser now. I use solvents as sparingly as I can, make sure there is plenty of ventilation, and I buy nitrile gloves by the box, and use two pair for solvents that I know will eat through them quickly. I bought heavy duty butyl gloves for working with alodine. I keep a mask with organic chemical filters handy, and use it often. I encourage others to do the same, preferably starting at a younger age.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 04-11-2016, 12:53 PM
rvbuilder2002's Avatar
A better alternative solvent for cleaning parts for tank sealant or painting is Naptha (AKA Coleman fuel).
It dries quickly with no residue. Is less toxic than MEK (but PPE should still be used).
It is basically what you get in the can when you by paint prep solvent such as PPG DX330, etc.
Scott McDaniels
Hubbard, Oregon
Old 04-12-2016, 06:03 AM
bruceflys bruceflys is offline
Remember that these chemicals can do nasty things to eyes as well as hands and lungs. My reader glasses provide small protection against splashes, so I wear a face shield like this: http://www.amazon.com/3M-Protection-...s=face+shields.
Bruce
Panther - Building 2019
RV-12 - Flying 2016; Sold 2018
RV-10 - Sold 2018; Flying 2018
SeaRey - Flying 2012; Sold 2017
Old 04-12-2016, 06:35 AM
Low Pass's Avatar
Low Pass Low Pass is offline
All
Joe Dallas
Joe,
Not trying to alarm you and I'm not an MD, but I did work in chem mfg industry quite a while. You might consider visiting your primary care doc and asking for a physical with a blood workup (look at liver function). I know that's likely not related to lung irritation, but I think liver impact when over exposed to VOCs and solvents. MEK and related materials enter your body/blood through your skin, as well as lungs. Your liver then takes the hit.
Best wishes.
Bryan
Houston
Old 04-12-2016, 06:39 AM
I have been taking a small pill for about 20 years, 125mcg levothyroxine, and will do so the rest of my life to replace what was produced by the thyroid gland.
The thyroid enlarged about 5 times and went retrosternal whatever that means, docs thought it was cancer, and it had to be removed. Turns out it was not cancer, cause unknown.
I know what caused it, same thing happened to another builder at the time. Breathing fumes of the stuff we use to build is hazardous to your health, just like flying.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
