Old 04-09-2016, 08:33 PM
pilot28906 pilot28906 is offline
Default WD-617 Canopy Latch Rubbing
I am fitting the WD-617 canopy latch and the C-611 bushing blocks but the WD-617 latch rubs the F-766A flap actuator channel. I'm not sure if I bent the F-767 attach plate wrong or if the bushing blocks are not thick enough to position the canopy latch away from the channel. Has anyone had this problem and what did you do to fix.
Thanks in advance,
John Johnson
Murphy, NC
RV7
Old 04-11-2016, 06:44 PM
Default Here is a photo of the problem
[IMG][/IMG]
John Johnson
Murphy, NC
RV7
Old 04-11-2016, 08:07 PM
Vonsmallhousen Vonsmallhousen is offline
I had a similar problem. The tube was rubbing on the rivets from memory. I removed the specified rivet and put flush rivets in. May be you could shim the blocks forward a bit.
RV7 ZK-DVS
Whangarei
New Zealand
EMS S76 Pilot
Old 04-12-2016, 05:41 AM
Thanks, I was thinking this might be a fix.
John
John Johnson
Murphy, NC
RV7
Old 04-16-2016, 09:13 PM
Talked to Van's and they said this happened some and to put some UHMW tape on the tube. The tube was too close for tape to help so I installed flush rivets and 1/8" spacers behind the nylon bearing blocks. No rubbing now! Canopy latch assembly finished and working.
John Johnson
Murphy, NC
RV7
