Originally Posted by bill v
I see this phrase in other posts what does it mean?
The audio electronics are rather particular about how the grounds are done, noise or other gremlins can be introduced due to poor grounding.
Not sure if other electronics besides audio stuff is as troubled by poor grounding but why take the chance?
Many folks just run all ground wires together, not just audio-------play it safe that way.
I used the forest of tabs mounted to the sub panel for all of the grounds of everything in my panel-------even indicator lights and such. I have no noise issues in the radios.
Forest is visible on left side of the photo--------just getting started here, by the time I was done, I ended up using every tab-------and even had to "Y" two wires into some terminals.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
