Old 04-06-2016, 07:45 AM
bret's Avatar
bret bret is offline
Default Wide deck Vs Narrow deck IO 360 width?
Does anyone know if there is a difference in the distance at the valve cover width between the two engines as far as the Vans baffle kit rear wall goes? or is this a trim to fit piece? I will be going with some type of plenum for the James cowl, heard bad things about the fit of the James plenum and looking for different avenues. buy a plenum cover? fab up something different? seen an all aluminum plenum on the 409 RV 8 race plane last Reno race.......
Old 04-06-2016, 07:57 AM
crabandy crabandy is offline
Default BillL's Plenum
I would contact BillL and see if he would make you one of his, unless you "really" want to experience building your own.
RV 7 400 hours and counting
19 donation done
Old 04-06-2016, 08:50 AM
bret's Avatar
I have contacted him on his a while back, very nice work. as a remember, I think his were for the parallel valve and was about 1 - 2 inches narrower that for angle valve....
Old 04-06-2016, 09:08 AM
airguy's Avatar
airguy airguy is offline
I would have to be a voice in favor of fabbing your own plenum - my experience with the James plenum was not positive, I have had to cut and hack every corner and one of the inlets to get it to work. I literally would have saved time (and not a small amount of money) fabbing it from scratch.
The James Cowl, on the other hand, was great.
Old 04-06-2016, 01:54 PM
lr172 lr172 is offline
I have never measured the two different cylinders, but would be VERY surprised to find one having a different installed dimension than the other. There is no Engineering reason to do it and convention would demand consistency.
Larry
Old 04-14-2016, 12:39 PM
rgbewley rgbewley is offline
The footprint of the engine should be the same whether it's a wide or narrow deck engine. The difference is in the size of the cylinder flange at the cases, not the height of the cylinders and should not affect the baffling.
Rhonda Barrett-Bewley
Old 04-14-2016, 01:22 PM
bret's Avatar
O.....so they should have called it a wide barrel or narrow barrel flange case? I thought it had to do with the width of the deck? wide DECK, narrow DECK? silly me.....thanks ;-)
Old 04-14-2016, 02:23 PM
TCONROY's Avatar
TCONROY TCONROY is offline
There is definitely a difference because the stock horizontal air intake snorkel was designed for the 200hp -A1A which is an angle valve and it stuck out about 2" wider from the valve cover than it needed to be for my -M1B parallel valve.
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
RV-7
First Flight - April 12, 2015
Construction Log
Old 04-14-2016, 02:41 PM
Walt's Avatar
Walt Walt is offline
The 200 hp angle valve motor is wider than the parallel valve, but as noted by our resident expert (Rhonda) the parallel valve wide and narrow deck are the same.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 04-14-2016, 03:56 PM
bret's Avatar
The parallel 360 is 31 1/2" my A1A angle valve is 33 1/2" at the rocker box baffle mounting surface.
