Old 12-23-2006, 06:12 PM
Default Tech data in threads
Just an observation - occassionally some really good tech data appears in these threads then the threads disappear. I think the message is if something shows up this way, one needs to copy and save it locally when first observed. I will start my own VAF folder I think and collect some of these gems until I get a chance to use them.
Bob Axsom
Old 12-23-2006, 09:26 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Bob - are you sure that the threads are going away? I only ask because I have frequently gotten null results on a search when I KNEW the topic was there...and it turned out I didn't set the "how far back" parameters correctly.
Then again, maybe Doug does some gardening to keep size within reason - I don't know...
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-23-2006, 11:51 PM
Default You are right
I was looking fot the Constant Speed vs. Controllable Pitch thread in the Propeller section. The section only had 4 threads displayed and it said below that 1 through 4 of 4 were being displayed. However, using the clue from your post I told the system by entries below the table of threads that I wanted to look back an extended period and many more threads including the one of interest showed up. Thanks, it was not apparent to me that there was a data structure maintained beyond the currently displayed threads. Still, it was a wake up call for me that if I think something is important I should take the action to record it for myself. It would be nice if a whole thread could be recorded - I will have to explore that.
Bob Axsom
Old 12-24-2006, 05:50 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Same experience but the threads are always there
Bob try less words like just
constant speed
controllable pitch
fixed pitch
controllable
constant
fixed
pitch
prop
propeller
I put in "controllable pitch" and got the thread.
If you put in "Constant speed vs. Controllable Pitch" you would not get it because the thread was:
"Constant Speed Prop vs. Controllable Pitch ". The extra abbreviated word "prop" makes it a non match.
Even if you left off the "." in vs. it would change it and make it a non match.
If the less word method gives you too many hits because its not unique enough, you can search just under your user name if you recall you contributed to it. The user name filter is under advanced options.
Some times I use the wrong word. Dang computers have to be so exact. Eventually it shows up with enough hunting and pecking. Merry Christmas.
G
PS: NOTAM please clear all airspace the Eve of Dec 25 for Santa and his crew of Reindeer.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 12-24-2006, 06:07 AM
wv4i wv4i is offline
Default CS vs FP threads..data search...
Example would be a recent thread re Sensenich FP prop, best pitch for a given airplane, etc., that morphed somewhat into FP vs CS prop. I know I put a couple comments on there since I've had both FP and now CS on my RV-6. So, just did a search for "CS Prop" and got more hits on apparently unrelated threads than I have time to read. Perhaps the advanced search would narrow it down a little more, even by poster if you can remember who's flying what, etc.?
Link McGarity
Wellington, FL (FD38)
RV6/N42GF bought flying, sold
RV6/N72AT bought flying, sold
B737-800/NxxxAN
Sonex TD w/Aerovee/N732SX bought flying
Old 12-24-2006, 06:56 AM
cytoxin's Avatar
cytoxin cytoxin is offline
Default hmmm
i have seen stuff turn up in a search like http://www.vansairforce.com/communit...+back+location
says its in the rv builder tip section but if i go to rv builders tip section its not there .
William Weesner/ still kicking.
Old 12-24-2006, 07:50 AM
sportpilot's Avatar
sportpilot sportpilot is offline
Default google
You can even do a search from google on the internet level and it will pull up Vans Airforce forum posts as well as other sites that include the subject. What a cool tool this internet is aye. Merry Christmas Y'all.
Claude Stokes (sportpilot)
Finished Building an RV-10 and a Titan Tornado 2
RV10 approaching 150 hours Vans kit 40418
See Pictures of the RV10 here. http://btconline.net/~sportpilot/RV10/boatright
Waycross, Ga. Airport KAYS
Old 12-24-2006, 09:00 AM
Mel's Avatar
Mel Mel is offline
Yep! Al Gore did a good thing when he invented the internet.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
