Old 04-01-2016, 11:25 AM
Default Can the internal regulator on Plane Power be adjusted?
Hi there:
Noticed the other day that the alternator was firing 14.4 at one point and Savvy Analysis had earlier taken notice of a file I sent them when it was 14.3, saying they'd rather see it no higher than 14.2.
I run a Plane Power alternator which has an internal voltage regulator. Is there any way to adjust it?
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 04-01-2016, 11:33 AM
Steve Barnes Steve Barnes is offline
Default Plane Power
Mine has always run at 14.2 to 14.4 for 1200 hours. No problems. I was told that if I wanted 14.1 that I would have to see if there was any resistance in my system and fix it.
Steve
Old 04-01-2016, 05:03 PM
Lycosaurus's Avatar
Lycosaurus Lycosaurus is offline
Default All good for a PC680
Originally Posted by LettersFromFlyoverCountry View Post
Hi there:
What battery? PC680 battery from Odyssey likes higher voltages. From memory I believe the ideal is in the 14.7V range, absolutely no higher than 15V. You might want to check the battery specifications first. I have same 14.4 voltage output from plane power, and all is fine and seems to charge up the battery fully (reads 13.0V indicating a full charge once surface charge has dissipated).
It is a fixed regulator, and as far as I know, no way to adjust voltage output.
Savvy Analssis likely refers to standard aviation flooded cell lead acid batteries like Gill etc. Different chemistry.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
