Old 03-31-2016, 08:55 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Default Dynon Introduces SkyView SE
Dynon is excited to introduce the newest member of the SkyView family. Dynon's new SkyView SE system offers a streamlined and simplified experience for pilots of simple VFR aircraft. The SV-D600 7" and SV-D900 10" displays are priced hundreds of dollars lower than existing SkyView displays.
SkyView SE
SkyView SE displays are made specifically for VFR aircraft and pilots who want the most intuitive flight and engine instruments on the market. They feature simple and clear displays, with almost no menus to navigate in flight. At the same time, SkyView SE retains modern, innovative Dynon EFIS capabilities like SkyView’s revolutionary COM radio interface and 2-axis autopilot with single-touch controls.
Without mapping capabilities, even the 7" SkyView SE display has a large, easy-to-read Primary Flight Display, including pilot-selectable six-pack "steam gauges". With its simplified feature set and installation, SkyView SE is the successor to Dynon’s legacy D100 series products (which remain available). SkyView SE systems configured like their D100 series counterparts are similar in price. SkyView SE displays have the same dimensions and mounting requirements as existing SkyView 7” and 10” displays.
Dynon expects SkyView SE to be popular with ultralight and simple light sport aircraft, where its low weight and low cost help make factory-built aircraft affordable. For aircraft in the US market, SkyView SE systems equipped with Dynon’s Mode S transponder and SV-GPS-2020 offer the lowest cost integrated glass panel system which meets FAA 2020 ADS-B Out requirements.
The 7” SV-D600 and 10” SV-D900 displays are priced at $1850 and $3100, respectively. A complete 7” SkyView SE system with primary flight instruments starts at $3305 including harnesses. For only $2790 more, SkyView SE customers can add the SV-XPNDR-261 Mode S Transponder (with ADS-B Out) and SV-GPS-2020 GPS Receiver/Antenna. Aircraft so equipped will be 100% compliant with the FAA’s upcoming ADS-B Out mandate.
SkyView SE is expected to start shipping in April 2016.
Features
Notes
1: Simplified Mode Only
2: No AP Controls: Trim Control & Autopilot Autotrim Only
3: Auto or Ext Knob Only
4: Via External Button
5: One External NMEA Source
More information, including an extensive FAQ, can be found at www.dynonavionics.com
Thanks!
Michael Schofield
Dynon Avionics
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 03-31-2016, 09:50 PM
N941WR's Avatar
N941WR N941WR is offline
Very nice Dynon!
Keep up the great work!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-01-2016, 08:40 AM
vlittle's Avatar
vlittle vlittle is offline
Brilliant!
I've been a long time critic of the growing complexity of EFIS systems. Doing the right things right and lowering the price may be the ticket for the LSA and the average sport plane builder.
Buried in the feature list are also hints about something else coming....
V e r n. ====
RV-9A complete
Harmon Rocket complete
Part of EAA award-winning OnSpeed team
The VV in huVVer.tech
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 04-01-2016, 08:44 AM
DennisRhodes DennisRhodes is offline
That is nice. Presently using a 7" D180 for all that. I could be one step closer if all my D180 plugs would terminate to a module or to the back of that SE and make a D180 upgrade to SE a quick job with no under the panel rewireing !! But, nice looking VFR unit anyway.
DRRhodes
2021 VAF Supporter
RV9 N908DR
Old 04-01-2016, 10:52 AM
az_gila's Avatar
az_gila az_gila is offline
Question Map version
Originally Posted by vlittle View Post
Brilliant!
Perhaps the next item would be a "Skyview SE-Map" version.
A moving map only display might be a good product and better than attaching (kluging?) an iPad in some fashion to your panel...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-01-2016, 01:58 PM
KRviator's Avatar
KRviator KRviator is offline
?...Buried in the feature list are also hints about something else coming....
I'm missing any subtle hints. What is it you see?
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 04-01-2016, 08:17 PM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
Checklists? I've been out of the game for a while though, so maybe those are already implemented...
Andy Compton, PhD EE
RV-10 #41414, N643AC (building)
RV-7A #72158, N808PA (flying)
RV-9A #91638 (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
Old 04-01-2016, 09:50 PM
vlittle's Avatar
I'd sooner not say...
V e r n. ====
RV-9A complete
Old 04-02-2016, 12:02 AM
lrgabriel lrgabriel is offline
Does this have an integrated AHRS or GPS antenna, or are those still remote?
Old 04-02-2016, 12:26 AM
Toobuilder's Avatar
Im liking the looks of this a bunch. Simpler is good. Keep the programming code short and sweet (and robust). The lack of capability to connect to an external navigator like a 430 or 650 seems like a step backwards, however. After all, I can do that with my D-10A today through the HS-34. Did I read the FAQ wrong on that point?
That said, when I do want to upgrade to a full featured IFR suite, is this product expandable to a "full" SV system?
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
