Best fit
is obtained by first fitting the intersection fairings to the wheel pant. You may have to do some layups to improve the fit of the intersection fairing before you move on. Then try sliding the gear leg fairing up or down to fit the intersection fairing better. Even after you've made your best fit, to get it perfect usually requires you to do some glass layups from the intersection fairing to the gear leg fairing. This area moves a bit, so you'll probably also have to trim up your layups once you're done. Some builders use some chafe tape on the inside of the intersection fairing once it's trimmed up, just to protect the paint on the gear leg fairing a little. Make sure you've got the intersection fairing placed onto the wheel pant with clecos before you go to fitting the gear leg fairing to the intersection fairing. If you haven't had them off and on a hundred times you're better at this than I was...
RV7A-QB, RV-10
