03-30-2016, 08:10 AM
The log books for my old C-152 indicated that a bucking bar was found inside the wing after a repair was made which bounced around and damaged the skin.
David C.
Howell, MI
03-30-2016, 08:13 AM
I see the problem in the first photo (landing lights should be mounted to the *front* of the wing), but I don't see it in the second... Can someone summarize?
Rob Prior
03-30-2016, 08:33 AM
Originally Posted by Ironflight
I seem to remember that when we took the rear-most inspection cover off of the RV-1's tail cone, we were able to add a couple of small tools to Jay Pratt's collection. So this is a phenomenon that goes WAY back..... (Not saying they were Van's tools, probably a subsequent owner!).
I seem to recall reading about a pair of pliers or something that was found wedged into the Spirit of St. Louis when they poked around some of the recesses with a camera. It could have been something else, but I thought it was the NYP.
Dale
Omaha, NE
Previous RV-7 project (sold)
03-30-2016, 08:40 AM
Just a guess but I'm thinking he was showing that the aileron bell crank was in that same bay and that the flashlight could potentially jam it some how.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
03-30-2016, 09:08 AM
A D-cell flashlight (not mine) in the flap motor bay of our 172. A combo wrench atop #s 1and 3 at the subsequent -7 oil change (Absolutely no idea who's that might be. Not my fault. Won't happen again.) I've become paranoid enough to undress whatever was open until I find every tool. And then there are times I forget I've forgotten something which fortunately appears as if by magic somewhere in the hangar where I never went. Un huh.
John Siebold
03-30-2016, 09:18 AM
That nut with the torque seal has got to be bottomed out also.
JimS
Built and flying a Kitfox IV / 912
Bought and flying an RV-6 / 0-320 FP slider
Built and maintaining a 1800' grass runway
LIVING THE DREAM!!!
03-30-2016, 09:50 AM
One time I was flying a chopper in Vietnam. (Marines) Began to notice the flight controls were getting awfully stiff. After landing, went up and started inspecting. Found a screw driver wedged between a flight control bell crank and the floor. Couldn't even get the darn thing out. Crew chief had to disassemble the bell crank to get it out.
03-30-2016, 11:30 AM
Hammer
Non RV related, but a few years ago I had an engine failure on 747-200, when the engineers opened the engine cowlings a hammer fell on the ground. Traced back with the serial nr to a mechanic who had worked on the plane on the last inspection a few weeks before. It was not the cause of the engine failure though.
So it happens everywhere, on every kind of airplane...
RV7 (F-PRVZ), Tip Up, Aerosport IO-375, Dynon Skyview, VP-X, Day VFR.
Flying since June 2017.
03-30-2016, 11:49 AM
Not sure what model RV that is...
but my first thought was that the pic was meant to point out that someone had jerry-rigged a bellcrank connection with a tall standoff and bolt that put tremendous bending load on the bolt and wasn't to plans. Apparently I would be wrong in that assumption. I will defer to the materials engineers on this. Still gives me the heebie-jeebies to look at that set-up, though.
-Stormy
03-30-2016, 11:57 AM
-Stormy
That is a spacer. The bolt goes thru the steel bell crank on both ends. The actual pivot point of the bell crank is not shown in that pic.
