Old 03-30-2016, 06:15 AM
Weasel's Avatar
Weasel Weasel is offline
Default Frightening
Found this during an inspection. No names
This is the same wing bay
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1700hr counting
RV-10 N7631T 820hr Sold
RV-8 700+hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 03-30-2016, 06:44 AM
Don Patrick's Avatar
Don Patrick Don Patrick is offline
Default OMG!!
Is that a flashlight??
How long has this A/C been flying?
Old 03-30-2016, 07:07 AM
phapp phapp is offline
Vans will need to pre-pend the heavy wing troubleshooting procedure:
1) Confirm there are no more than 2 pounds of forgotten tools and equipment in the heavy wing.
Seriously though, I can see how easily this could happen to any of us. You get distracted between what you opened the inspection cover for and when you're done and ready to put the inspection cover back on.
So just being reminded that this can happen is helpful. A simple rule when working on our aircraft would be:
"Prior to replacing any inspection cover or fairing, confirm all tools removed and accounted for."
2021 - 2022 Dues Paid
N423PH Schweizer 1-23 (Sold)
N83881 Champ 7AC
N446PH RV8 (reserved)
PA-25 Pawnee Glider Tow Pilot (volunteer)
CallAir A-9 Glider Tow Pilot (volunteer)
Old 03-30-2016, 07:45 AM
fixnflyguy fixnflyguy is offline
It happens more often than you'd care to know..even on the big planes.As others have said, it's always a good idea to make a final look with a mirror and light before any closing of panels. I personally have a fairly organized tool box and tote that is inventoried after each use, and plane is a no go if a tool is missing. If a friend comes by when I'm working, I stop what I'm doing, as the "help" is often a distraction that leads to something overlooked.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 03-30-2016, 07:53 AM
Toobuilder's Avatar
I found a bucking bar in the right wing of my Rocket when I opened it up the first time. Also found a 7/16 combination wrench in the aft fuselage on the RV-8 on first inspection.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 03-30-2016, 08:00 AM
Mel's Avatar
Mel Mel is offline
I've found everything from clecoes to torque wrenches during inspections.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-30-2016, 08:17 AM
acam37's Avatar
acam37 acam37 is offline
The first thing I learned in Navy aircraft maintenance school was tool control. The plane should never be flown until all tools are accounted for. We had special tool boxes with inventory sheets to make sure this didn't happen.
Arlie Conner (A&P)
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) completed 3-17-19
KOCH Nacogdoches
Old 03-30-2016, 08:22 AM
cguarino cguarino is offline
Default Tool control
That is why the Air Force labels and accounts for every tool that goes out to work on a jet and won't release the aircraft until all the tools are accounted for after the work is done. It is a real PITA but works. BTW, same here as for my experience with finding tools. I've add a few good tools to my collection.
Charlie "T.Bear" Guarino
Springtown, TX
RV-4 Flying again with a fresh overhaul
Exempt but paid
Old 03-30-2016, 08:37 AM
DaleB's Avatar
DaleB DaleB is offline
My first reaction was, "Bonus tool!" I found a nice little Mag Lite in my wing the first time I opened it up. Then I saw it was in the same bay as the aileron bellcrank. Yeah, not good.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 03-30-2016, 09:01 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I seem to remember that when we took the rear-most inspection cover off of the RV-1's tail cone, we were able to add a couple of small tools to Jay Pratt's collection. So this is a phenomenon that goes WAY back..... (Not saying they were Van's tools, probably a subsequent owner!).
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
