  #51
Old 05-20-2011, 12:05 PM
gasman gasman is offline
Originally Posted by Capflyer View Post
By the way, also in the Flight Jacket kit is Oil & Exhaust Remover. This stuff does an incredible job of cleaning up my belly after blowing smoke. It emulsifies the oils so they come right up as opposed to other cleaners where it just loosens it and smears it around.
GUNK on a wet rag will do the same thing.
Old 03-14-2016, 01:01 PM
Darren S Darren S is offline
Default Canopy / Windscreen cleaner polisher
Hey guys,
The windshield of my -7 has some very fine white paint over spray on it. I can still see out of it fine, but sometimes when the sun reflects on it, at a certain angle, it looks terrible.
Does anyone have any suggestions for a safe cleaner/polisher that I can use to try and remove the paint flecks?
Darren
Old 03-14-2016, 01:45 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Novus #2: http://www.aircraftspruce.com/pages/...vuspolish2.php
Use sparingly.
If really bad or you have deep scratches, Novus #3: http://www.aircraftspruce.com/catalo...ickkey=3033989
Then #2.
After cleaning, use Novus #1 (and use this for all cleaning):http://www.aircraftspruce.com/catalo...ickkey=3033989
I used #2 to remove paint fog that got under the masking on an RV-8 canopy. Worked perfectly.
I carry #1 in the plane and it is the only thing allowed on my glass.
Carl
Old 03-14-2016, 04:02 PM
BABALU BABALU is offline
I used NON acetone fingernail polish remover. It worked perfectly. I bought the
Pre soaked wipes.
A C Tyler
RV 9A
Old 03-14-2016, 10:01 PM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
http://www.vansaircraft.com/pdf/Acry...ndow_Hints.pdf
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
Old 03-14-2016, 10:04 PM
lr172 lr172 is offline
Originally Posted by Darren S View Post
Hey guys,
Darren
What kind of paint was the overspray from? Rattlecan paint should come off with mineral spirits which is approved for acrylic. 2 part paints could be more problematic and require more rubbing with possible swirl marks. I have very good luck with clay bars on my cars. It will get off even 2k paint overspray if light. I can't see any scratches in the clear coat afterwards, but that doesn't mean you wouldn't see them on clear acrylic. You can try it in an inconspicuous area.
EDIT: I now remember having my plane on the driveway when I sprayed my cowl and other F/G parts (2K single-stage). I got light overspray all over the plane, including the rear canopy (unfavorable wind shift I didn't notice). Came off easily with the clay bar and detailing fluid. I don't remember any scratches that it left on the acrylic.
Larry
Old 03-15-2016, 04:38 PM
Thanks for the great info
Darren
Old 03-28-2016, 12:59 PM
jimbo jimbo is offline
I believe Steinair used to sell a plexicleaner polisher by the name of Allclear. I couldn't find it listed on their online store and also not listed at ACS. I used this product the last few years and was happy with the results. Any one know where it is still available?
Jim
RV9a
Flying since Sept 2013
Old 03-28-2016, 01:46 PM
vasrv7a vasrv7a is offline
Jim
RV9a
yes...
http://www.aircraftspruce.com/catalo...?clickkey=8238
Old 03-29-2016, 09:31 AM
Thanks. I see my search skills are not the best.
Jim
