Old 03-24-2016, 03:14 PM
sblack sblack is offline
long live experimental aviation!
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 03-24-2016, 08:52 PM
Ebbe Ebbe is offline
Originally Posted by kamikaze View Post
I want to hear about the underlying software!
Linux core? Some other RTOS? What kind of bus is it? CANBus presumably, but configured how? Industrial-rated components or better? C, C++, ADA, other?
Is the EFIS board COTS? Which one?
If you want to take this "commercial", I certainly hope the experimental kit model of plans & parts would be how it could be sold ... though of course there's the software question ... I think OSS + plans & kits hardware would be a neat way to go ...
JF,
it's currently running under XP Embedded. This was just to get things up and running, and allows for an easy port to CE. All software is written in C. Hardware is an industrial Atom N455 in PC/104 form factor, mounted on the main EFIS board which uses Microchip MCU's for CAN, PWM (brightness), debouncing hardware, level converters (RS-422) etc.
CAN bus is running at 250kb/s. Not sure what you mean by "configured" -- with 20ppm clocks and <1m node lengths, the tq/segment setup is simple. A higher level ACK/NAK protocol is used for critical messages, but most are not, so they are just fired off "one-way".
- Ebbe
RV-7A, purchased from builder
IO-360, ~450 hrs
Avionics: own design
KMMI - Athens, TN
Old 03-24-2016, 09:18 PM
Originally Posted by petehowell View Post
I am at KANE up north and would love to see your setup! Thinking about doing it is one thing, DOING it is a whole 'nother level.
Great work!
Hi Pete,
Just shoot me an email when you are ready to come down to Fleming. I'm at the north end of the field, right behind the beacon. There most weekends.
- Ebbe
IO-360, ~450 hrs
KMMI - Athens, TN
Old 03-24-2016, 09:22 PM
Originally Posted by BobTurner View Post
Have you thought of tackling building a GPS navigator that meets the TSO (I think it's 145/146?) requirements for IFR use? There's a real market there for the right box at the right price.
Bob,
Help may be on the way. The more I read about it, the more doable it sounds. Another good challenge, not that I need it....
- Ebbe
IO-360, ~450 hrs
KMMI - Athens, TN
Old 03-25-2016, 05:43 AM
kamikaze kamikaze is offline
Originally Posted by Ebbe View Post
JF,
- Ebbe
Windows! That's an option ... licensing costs however (They don't seem to sell licenses through their store also) ... but does simplify things greatly ... My efforts in this area have been focused on sticking with "openness" (Linux on Intel with open-source everything) ... it's been a challenge but I am getting closer. Finding a board that does everything COTS is also a challenge. but i did find ways to use PC/104 with the right daughter boards ... not sure how such a setup will endure shock/vibrations though ...
I was wondering whether you used "real-time" canbus (Forget the spec right now ...) ... but looks like no one really bothers.
Anyways, very nice ... that's a whole lot of time spent away from your actual build also ... or was the plane already built when you undertook this challenge?
J.F.
Sling 4 empennage kit on order!
Future EAA 245 Member (Hopefully)
Current Piper Warrior PA-28-151 Owner/Pilot
Ottawa, Ontario, Canada
http://www.sling4.ninja
Old 03-25-2016, 07:52 AM
On a different note, I really like the airliner like PFD/MFD/EICAS-like layout ... the screens are far less cluttered ... but it's a tight fit!
J.F.
Old 03-25-2016, 08:01 AM
jdeas's Avatar
jdeas jdeas is offline
Default CAN bus
Not so, I have benn flying with a distributed power,trim and flap system for the last few years based on CAN. AIRINC 825 and CANaerospace specs are out there.
Here is the paper I presented at Osh a few years back.
http://jadsystems.com/CANaerospace_OSH_2009_Paper.pdf
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
Old 03-25-2016, 08:04 AM
N395V's Avatar
N395V N395V is offline
I contemplated building my own avionics once but gave up when I couldn't find enough vacuum tubes.
Milt Concannon
Old 03-25-2016, 08:09 AM
Kevin Horton's Avatar
Wow! You've certainly raised the bar on designing your own panel
How well does the AHRS work? Do you use pitot/static or GPS inputs to stabilize the attitude algorithm, or does it manage to maintain stability without any assistance? How well does it realign in flight, if needed?
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 03-25-2016, 08:46 AM
Steve Melton's Avatar
dude! that's impressive. I bought a PLC display a year ago so that I could make an engine monitor but it's been on the back burner. I think there is some opportunity here for the experimental group to benefit.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
