Old 12-21-2006, 05:35 PM
Scott Will's Avatar
Scott Will Scott Will is offline
Default Pitot mounting - how to ensure correct angle?
Ever since first flight my indicated airspeeds have been off. It gets worse as velocity increases. I have the Dynon AOA probe hooked up to my mechanical and GRT display (they agree pretty well). Static system checks out via an IFR check and flying in formation with other aircraft.
I'm wondering if the pitot tube itself isn't tilted up or down. That would definitely throw things off (I remember that from college days! we did experiments mounting pitot tubes at different angles in the wind tunnel).
I have the Gretz Aero pitot mast. Did any of you have to shim it at all? I just ordered a new one and noticed in the directions about adding a washer.
Wonder if there is a way to determine the correct angle... maybe with longerons level?
Scott Will
http://will2fly.com
CFI - CFII - MEI
FLYING RV-7A IO-360 @ KPDK
Old 12-21-2006, 07:51 PM
aadamson's Avatar
aadamson aadamson is offline
Scott,
I just poked Tim Olson who had similar issues on an RV-10 and resolved them. A couple of notes tho.
Mathematically these may not make any sense. But I'm not pitot genius.
a) while static could pass the IFR cert, the ASI uses "differential" between pitot and static to determine where it should read. Do some looking for how to build a "mamometer" I think a pitot system can be checked with specific inches of water, etc.
b) I'm pretty sure that Tim looked in to the "angle" topic and determined that it really didn't make that much difference. However, what he did find was that his static ports (which also passed an IFR cert) and simple altimeter comparisons, we most of the effect. I can't remember if he used a kind that protruded and then went to flush mounted ones, or vice-a-versa, but they ultimately solved his low reading.
Like I said, I poked him, so maybe he'll show up and educate us all.
Have fun, I'm jealous!
Alan Adamson
Atlanta, GA
Lancair Legacy FG-6 - N60AL (fixed gear, carbon fiber, IO-550)
Lancair Legacy Builders Forum
Beta Test Blog of Vertical Power install
Old 12-21-2006, 08:20 PM
Scott Will's Avatar
It's very true and simple Bernoulli to determine that airspeed uses the difference between total and static (not the true difference, there's some math involved, but the main variables are those two items).
While I have the flush mounted ports and I know there have been posts about them, I believe my static system is fine because you and I flew side by side in your fancy G1000 182 and I matched you within a few feet. That tells me that the static pressure is OK.
And few flights ago I put a raised strip right in front of the static ports held on by aluminum tape... that didn't help at all.
Scott Will
http://will2fly.com
CFI - CFII - MEI
Old 12-21-2006, 08:27 PM
mh53j mh53j is offline
Default pitot angle
Scott,
From the tunnel experiments you did, there should have been negligle affects up to about 20 or 30 degrees from freestream velocity. Most pitot tubes are "good" to 20-30 degrees from V infinity depending on who's book you read. I worked for an aircraft manufacturer and it took about 8 months to get the pitot-static system right on a prototype aircraft. It sounds suspiciously like a static problem. My 2 cents.
Brett
Old 12-21-2006, 08:34 PM
Scott Will's Avatar
If it's a static problem, then my altitude and vertical speed should be off. As far as I can tell, they are OK.
Scott Will
http://will2fly.com
CFI - CFII - MEI
Old 12-21-2006, 08:35 PM
aadamson's Avatar
I guess what I'm just not trusting, is the altimeter as the indicator that the static system is "aeronautically" correct...but this math stuff is too hard for us normal guys anyway ...
So, let me ask.... How hard would it be to change your static ports to the vans type that poke out a little? If simple, I can't believe the ports are very expensive. Only way to *really* know ...
Alan Adamson
Atlanta, GA
Old 12-22-2006, 05:56 AM
Kevin Horton's Avatar
The airflow under the wing is roughly aligned with the wing skin. The pitot tube should be accurate as long as it is aligned within about 15 degrees of the airflow (info from a NACA or NASA report). It is quite unlikely that pitot tube misalignment is the cause of this problem, assuming your pitot tube is pointing straight ahead, and is roughly aligned with the bottom wing skin. A pitot leak would cause a low ASI reading. Have you done a leak check?
I've seen more than one report of flush static ports causing airspeed errors on the order of 10 kt at cruise speed, with the error being less below that. This would lead to about a 100 to 150 ft altitude error, but would have essentially no effect on vertical speed, as the vertical speed reads altitude changes, not absolute altitudes. The altitude error would be hard to see by comparison with another aircraft, as each aircraft has an altimeter error of 50 to 75 ft.
Supposedly one of the flush port manufacturers changed his port design to make it stick out above the skin to address this problem. I haven't seen any test results that prove or disprove this claim.
How are you determining your airspeed error, and how much error do you have? Some people try to use inaccurate methods, such as averaging GPS ground speeds to get TAS. This method is only accurate if there is zero wind.
Have you checked the ASI for instrument error? Even EFIS ASIs can have errors.
For lots more info see the info on pitot-static system calibration on my web page.
I'm on the road right now visiting relatives over Christmas, and have very infrequent web access. I'll check back in a day or so, I hope.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 12-22-2006, 07:45 AM
db1yg's Avatar
db1yg db1yg is offline
Scott,
Make a simple little washer from aluminum. Make it about 1/2" in diameter and about .040 thick. Drill a hole in it the same size as the static port hole. Round the edges of the washer. Temporarily afix it over your flush static port (you must be sure the holes line up and that it will stay put!!). Go fly--use your gps to capture ground speeds and Kevins spread sheet to convert it to TAS. I will bet you a beer that a large portion of your error goes away!!
Pitot tubes can be significantly out of alignment with the aircraft and still be accurate. Dynon's pitot has a significant range--don't remember what it is exactly but it is on their web site.
I also had NO NOTICEABLE error in my altitimeter while my airspeed was 7+% off. It was the flush static port! As mentioned in your other thread on this issue I put in 2 months and many tests to correct this situation. You have identical equipment, an identical main airframe, and the same symptoms.
Isn't VAF a great resource!
db
RV9a/ECI0360/James Cowl/Catto prop--90 hrs and a permanent smile!!
Old 12-22-2006, 01:51 PM
Default OAT error?
One more thing to think about - OAT accuracy. You need to know the OAT to convert between CAS and TAS. Some people put the OAT probe in a NACA scoop on the forward fuselage. Many people have found that OAT probes in this location over read - if you used a too high OAT value to convert from TAS to CAS, if could lead you to believe your CAS was reading too high. 3 deg error in OAT is equal to about 1 kt at RV cruise speeds.
Also, there may be three or hour degrees C of ram temperature rise on the OAT indication at RV cruise speeds, depending on the recovery factor of your probe. You can check for this by flying at as high a speed as possible at a constant altitude until the OAT indication stabilizes. Then slow down to as slow a speed as possible at the same altitude, and let the OAT stabilze. If the two OAT readings are the same, then there is either no ram temperture rise, or it is being corrected for by the EFIS. If the OAT indication varies with speed, then gather enough data to know how the indicated OAT varies with speed, and figure out what recovery factor you need to correct for it.
IOAT = OAT + K * (TAS ^ 2) / 7592
IOAT is indicated OAT in deg C
OAT is the actual OAT in deg C
K is the OAT probe's recovery factor. Usually somewhere between 0.8 and 0.95, but it could be lower in some cases
TAS is true airspeed in knots
Plot IOAT vs (TAS ^ 2) / 7592. The slope of the line is K, the probe's recovery factor.
Kevin Horton
RV-8
Moses Lake, WA, USA
Old 12-22-2006, 02:17 PM
Originally Posted by db1yg
Scott,
db
I agree, db.
At one point with a previous homebuilt, I had 3 ASI's hooked up to the same pitot tube but with different static sources, plastic tubes and instruments laying across the right seat.
Finally, with much "fence" experiementing at the static port, I got the primary ASI reasonably accurate. As I recall, it was a .035 dam aft of the port that worked best.
It's a different challenge with every airplane, but I bet some experiementing with the static port, as you suggest, will make it better. It doesn't make sense that this works with a good altimeter reading but there's more going on here than we know about, so it is probably true.
dd
