Old 03-21-2016, 08:49 PM
walkergp walkergp is offline
Default Mixture Arm Interference with Starter
I have installed Van's mixture bellcrank and bracket for an IO-360A1B Horizontal Induction. When I connect to the mixture arm I am unable to get full throw due to interference with starter (see pic). This engine installed in another aircraft was configured with the arm in the down position where there would be no interference. Van's said I either need a shorter starter or modify the arm to avoid the contact. Even if I use the lower hole and cut off the top portion it does not look like I will still get full throw.
Any suggestions?
Greg Walker
RV-8A
Old 03-22-2016, 09:44 AM
airguy's Avatar
airguy airguy is offline
Reroute the cable?
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 03-22-2016, 09:57 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Can you turn the injector servo to a different position--------clock it 90* ???
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-22-2016, 08:39 PM
Boyd Birchler Boyd Birchler is offline
Default Mixture arm issue
You have an offset arm, it appears that a straight arm would clear.
Old 03-22-2016, 10:17 PM
Thanks for the ideas!
airguy - Rerouting the cable could be done from the bottom like the prior installation of this engine. I assume Van's had a reason for routing it above the sump. My exhaust is supposed to be delivered any day so that will give me a better chance to look for alternate routing.
Mike S - Not sure I understand clocking the injector servo?
Boyd - I think a straight arm would clear the starter. Might need a longer bellcrank as it appears the angle would be too oblique for the mechanical advantage. Do anyone have a source for these arms?
Greg
Old 03-23-2016, 07:11 AM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
Default Question
Hi,
May I ask what make and model starter you have fitted ?
Jan
Slooow RV6, no hole, builder in UK
Paid up for 2015 ...
Old 03-23-2016, 07:18 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Just did this
Hi Greg,
Just went through this last week. You'll notice the arm attached to the mixture is locked by teeth like a gear. Loosen the nut and move it forward one tooth at a time. I think I moved mine a tooth or two. Check the travel.
I am clear of the starter but only by 1/8," but it is clear and everything is smooth with full travel.
[quote=walkergp;1064119]I have installed Van's mixture bellcrank and bracket for an IO-360A1B Horizontal Induction. When I connect to the mixture arm I am unable to get full throw due to interference with starter (see pic). This engine installed in another aircraft was configured with the arm in the down position where there would be no interference. Van's said I either need a shorter starter or modify the arm to avoid the contact.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Painted and Complete
2021 Gold Lindy Grand Champion Kit Plane
Old 03-23-2016, 08:26 AM
Bill Dicus Bill Dicus is offline
Default Interference
I did not use the Van's bracket. Flipped the arm down and made a simple bracket of bent steel, attaching by two bolts to a flange on the case of my IO-360M1B. This allowed direct movement with no reversal of action and has worked flawlessly for 50 hours. Will try to post pic. I believe others have done something similar. Good luck and please post your solution. Thanks.
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
Old 03-23-2016, 09:47 AM
JonJay's Avatar
JonJay JonJay is offline
Remember, if you flip the arm the opposite way, you reverse the operation.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-23-2016, 10:07 AM
Toobuilder's Avatar
Yes, but when you dump the Rube Goldberg bellcrank, you "unreverse" the action, and it works fine.
I did this change on the -8 and it works great. With Van's focus on simple and light, I never could understand why he added the extra complication of a bellcrank.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
