Old 03-21-2016, 10:31 AM
AndyRV7's Avatar
AndyRV7 AndyRV7 is offline
Default Quick fiberglass repair question.
I have some wheel pant work to do. I read the old threads I could find but came away unsure. Is it epoxy resin I need?? Also, is 4 or 6 ounce cloth appropriate? Thanks! Andy
Old 03-21-2016, 10:49 AM
sapeloson's Avatar
sapeloson sapeloson is offline
Default Yes
Epoxy resin for all Vans FG parts. I used 3 to 4 ply of 8oz bi-axial cloth to make my pant leg fairings and build up for riveted areas. Just depends on what you are doing. I'm sure if you already have some 6 you'll be fine, just adjust number of plys to suit your needs.....BTW nice rooster!
RV-8
Phase 1 Flight Testing
Garmin IFR by Stein
Lycoming IO-360 (180HP)
MT 3 Blade CS
N84TH / Registered and GA sales tax paid! $@&!;:?)(!
N3159F C-182 @ KJES
Old 03-21-2016, 11:07 AM
AndyRV7's Avatar
That's great advice. Thanks! I have some 4ounce in my surfboard ding repair box. I think I'll add some 6 and 8. I'd be curious to see some pics or hear about your leg fairings. Did you have to build a positive form to glass?Thanks again.
The Rooster was my largest. Down in Panama 2 years ago. Andy
Old 03-21-2016, 01:38 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Fiber glass
Hi Andy. Done a fair amount of fiber glass work in my life.
Give a shout if you like can go through it with you. You should not
Need a mold. 401-862-5577.
Al
Al Girard, Newport, RI
N339AG
RV-9
Old 03-21-2016, 01:50 PM
AndyRV7's Avatar
Thanks Al. May have a question or two.
Old 03-21-2016, 01:59 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Take a look at this thread, you might find it helpful.
http://www.vansairforce.com/communit...highlight=pant
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-21-2016, 02:53 PM
AndyRV7's Avatar
That was a good thread Mike. One of the ones I reviewed. And it still had pictures!!
Old 03-23-2016, 05:49 PM
sapeloson's Avatar
Default Shaped Clay
Used clay to shape the form then layer the glass over that.... Still have a lot of topside finish work to do but, headed the right way.....
Just got back from Boca Chica ..... First trip to Panama, had a blast! Spent a week fishing our way up the coast from Panama to Los Suenous...... Have to be careful not to spend my plane money on fishing trips....... Not doing so good....
http://www.mykitlog.com/users/catego...category=10251
RV-8
Garmin IFR by Stein
MT 3 Blade CS
N3159F C-182 @ KJES
