Keep VAF
Going
03-20-2016, 08:00 PM
Wing Rib Rivet Callout Page 14-5 "4 Places"?
RV10 Wing section - Page 14-5 (bottom left corner) calls out AN470AD4-5 "4 places" for the next to last outboard and 3rd from last outboard ribs.
There are 8 holes in these ribs mounting them to the spar. Is this just a typo, should it read "8 places" instead of "4 places"?
Steve
03-20-2016, 08:46 PM
4 for center rib flange, 4 for nose rib flange?
Actual repeat offender.
03-21-2016, 04:41 AM
Good idea but nope.  Just checked the drawings, Ribs are attached by 8 different rivets. I am thinking this may be a typo, will try to call the mothership later today to confirm.
03-21-2016, 05:08 AM
8 places
Revision 1 of the drawings (PDF files from Van's) call out 8 rivets for these ribs.
03-21-2016, 06:30 AM
I vaguely remember this, yes there are 8 rivets and not 4. Nothing else attaches or sandwiches here, and if I remember correctly we did install all 8 for each of the outer ribs (except of course the outermost one which is only supposed to be cleco'ed) at this time.
A word of caution, I posted something about it here a while back, but on the very next page when you start to install bolts, pay extra-special attention to the hardware callouts. Some of the places call for 2 washers instead of just one (even though only one is depicted). If you only install one, the bolts may appear to snug up just fine but actually bottom out on the threads.
Mike Jimenez & Sarah Hammonds
EAA Chapter 33 Prez & Soc Chair
Marion, IA USA
RV-10 In progress! (N165MJ reserved)
-Emp & Wings complete
-Panel wired up, working on Fuse & Finish
-Blog horribly outdated (sorry)
-Too many distractions, we will finish the plane someday!!!
http://mikeandsarahrv10.blogspot.com/
http://www.eaa33.org/
03-21-2016, 06:36 AM
We may have a doc control issue... my page 14-5 Rev 1 shows 4 rivets???
03-21-2016, 08:37 AM
Could be. My REV 1 shows 8 rivets.
David C.
Howell, MI
RV-10: #41686 Under Construction/Sold 2021
"Donor Exempt" but donated through Dec. 2021
03-21-2016, 03:53 PM
Doc control issues - warning about Ailerons
My paper plans drawing 14-5 is dated 7/24/14 and marked as Revision 1. It incorrectly calls out 4 rivets in those locations, as pointed out by the OP. The PDF plans, also labelled as revision 1, have a date of 12/31/03 marked on them, but correctly call out 8 rivets.
An even more amusing documentation control issue may be waiting for you in section 21 - Ailerons. Here, the entire section is a problem. My paper plans are marked "Revision 0" and dated 24 July '14. The parts I have (kit #41581) do not match the drawings. There is no steel bracket, for instance. The PDF plans for section 21 are marked "Revision 1" but the date is, interestingly, 24 Jul '12 - so according to the dates, the revision levels are counting backwards! However, the parts I have in the kit do indeed match the PDF plans.
I concluded that the date on my print set drawings is wrong, and that around 2012 after changing the Aileron design for the RV-14, Van's decided to update the RV-10 kit with the same design (since the 10/14 Ailerons are identical) but in so doing made a mess of the documentation control.
03-21-2016, 09:35 PM
Yep I talk to this in one of my videos. The drawing shows more holes than the text says.
Do them all.. =) I did.. (I did this last month)
03-22-2016, 09:20 AM
As I start to build my -10
I'm going to be picking up where the original builder left off several years ago, with kits and printed plans of varying vintages. I intend to walk-through all of his already-completed steps to familiarize myself with the build and double check for errors (as well as documenting this part of my efforts to help pave the way for repairman's cert eligibility).
I can tell this is going to be very interesting, kinda like an A&P searching years of AD files to complete an annual. I take it that the PDF's available somewhere from the mothership are preferred to the printed plans that conveyed with the kit itself. But that there may be no way to ensure that even these have resolved all previous known discrepancies
One bite at a time; the first is always the hardest.
-Stormy
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
