Old 12-21-2006, 08:04 AM
tomcostanza tomcostanza is offline
Default Fiberglass Supplies
I'm going to place an order for supplies for the fiberglass work. Shipping and handling being what it is, and considering it is usually cheaper to ship one big box than two small boxes, I want to order everything at once.
What supplies have you used, or wish you had used, and where did you get them? I'm going with West epoxy based on numerous recommendations.
TIA and have a great holiday everyone.
Tom Costanza
RV-7A Fuse
Old 12-21-2006, 11:43 AM
brian's Avatar
brian brian is offline
Default Soller Paddles
Best West System prices I found were at Soller Paddles; friendly, prompt, knowledgeable, helpfulhttp://sollerpaddles.com/Epoxy.html
Brian Meyette, Cornish, NH
1995 RV-6A - N16RK (Ralph Koger) SOLD
RV-7A - incomplete, supercharged Subaru STi - N432MM - SOLD
2001 Quad City Challenger II LW - N28RT SOLD
www.meyette.us/RV-7Ahome.htm
Old 12-21-2006, 11:48 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I don't know where you're located Tom, but check to see if there is a West Marine within driving distance - they have all of the West Systems stuff, and yo can avoid shipping charges!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-21-2006, 12:27 PM
fstringham7a fstringham7a is offline
Tom
West System is great...but...before you make that order giver the folks at
http://www.avtcomposites.com a call. I have used their fiberglass material for years. It performs great.
Frank @ sgu and scl RV 7A
Old 12-21-2006, 03:03 PM
TSwezey TSwezey is offline
Any good boating supply place should have all the stuff you need. I used the West system plus I got some micro balloons for canopy. I also used Bondo Glass, fiberglass and Ultimate Bondo for the all the tips. You should be able to get the Bondo and the Fiberglass at Home Depot or Walmart.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 12-21-2006, 08:59 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Epoxy and sources
I'm the type that like to order from one source if possible. For most of the stuff you need you can order from www.cstsales.com. I used them for most of my glass stuff for the RV and for my RC stuff.
Here's some basic stuff that will get your canopy done. Also if you want to fair in your glass empennage tips.
1 quart West Systems 105 Epoxy
1 pint of 206 hardener
Set of metered pumps (MANDATORY) After getting the pumps, use a Sharpie and mark the halfway point on the stroke of the pumps for smaller quantity use.
Small container of 410 micro filler
1" Wide glass tape 10 yrd pack (if you are going to glass in the tail stuff)
.007 thickness
2" Wide glass tape .007 3yrd pack
3" Wide glass tape .007 2-3yrd packs
Mixing cups
Box of popcicle sticks from craft store
Stuff from the Auto body supply place
1 Quart Rage auto body filler
1 Quart Evercoat 416 metal glaze. (great for glass work so don't worry about the "metal" label)
Several small squeegees.
I also have 6 oz bottles of 5 minute and 30 minute epoxy from the hobby shop for small and quick jobs
This will cover virtually all of the glass work supplies you will need. I did two airplanes with 1 quart of epoxy and hardener.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
