Old 03-19-2016, 11:00 AM
AAflyer's Avatar
AAflyer AAflyer is offline
Default Fireblock failure...Don't do what I did.
After what I thought was much judicious research, I found an off-the shelf product to use in sealing my firewall; 3M FB136.
Unfortunately, while working on my baggage door, I discovered that it has cured rock-hard, has cracked, lost its integrity and has leached a white powder.
The label says its for "sealing interior construction voids around wires, pipes, HVAC ducts and vents, in wood or steel framed non-rated construction." I figured the interior restriction was not a problem, as it wasn't going to be exposed to the weather where I was using it. The label also says Store at temperatures above 32 degrees F. Again, not a problem as far as storage is concerned.
I applied this to my plane last fall, and since then it has been as cold as 5 degrees F this past winter, and this is the result.
I'm now chipping it away, and would love to hear some successful stories about what you used.
Bruce Windom
QB RV-8 N148BW
First Flight: Oct '16
AeroSport Power IO-360 180hp w/dual P-Mags
Catto 3-blade, with black carbon spinner.
10" Dynon SkyviewTouch. That's ALL.
Old 03-19-2016, 12:28 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
I don't understand why you thought this was necessary.
For oil seepage and such, pro-seal works well.
Carl
Old 03-19-2016, 02:50 PM
tnelson's Avatar
tnelson tnelson is offline
Default Biotherm
This is what I used, recommended by many..it dries like RTV and stays elastic.
http://www.planeinnovations.com/prod...otherm-bts-02/.
Good luck
Todd
7FL6
RV-10 SB Fuse
Emp & Wings Done
Old 03-19-2016, 03:06 PM
flyboy1963's Avatar
Default ....what's in a name?
Rectorseal Biotherm 100.
..........okay guys, I'm pretty sure my doctor used this after my last colonoscopy!....
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 03-19-2016, 03:34 PM
David Paule David Paule is online now
You guys should read this thread.
Dan Horton has done some interesting tests and reported results for some of these materials.
I'll be using 3M Fire Barrier 2000+ on my RV-3B.
Dave
Old 03-21-2016, 03:01 PM
ppilotmike's Avatar
Default +1
Dave
Per Dan's research, I am using the 3M Fire Barrier 2000+ on the firewall of my RV-10. I am also using 1/8" Fiberfrax on the firewall and 1/16" Fiberfrax on forward part of the fuse belly, sandwiched between the SS or aluminum skin and a layer of 0.001 thick stainless steel sheet.
Mike Rettig
VAF Dues Current
RV-10 - Working on engine / prop installation
