Old 03-19-2016, 07:08 AM
chris mitchell chris mitchell is offline
Default Alternatives to AN365-1032 nuts?
Because of a lack of foresight and intelligence on my part I have some conflicts between the nuts/bolts that tie the engine mounts to the longhorns and the nut plates for the screws that hold the forward top skin in place (RV-4). The bolts all go in fine but I can't get a couple of the standard AN365 nuts on. If I use an AN-345 and grind it a little I can just slip it into place -but I wondered if there was any other better alternative in this situation? The only other choice is to find another way to secure the top skin and grind away the offending nut plates....
Chris
Chris Mitchell
Repeat offender;
RV-8, QB, built, flown 150 hours, sold;
RV-4 - attempted repair, rebuild and remediation - abandoned and junked ;
RV-4 fuselage and wing kits - both at QB stage;
2015-2018 dues paid!
Old 03-19-2016, 07:21 AM
Sam Buchanan's Avatar
been here awhile
Chris
Maybe this would work:
http://www.aircraftspruce.com/pages/...ex/ms21042.php
Sam Buchanan
RV-6
Fokker D.VII replica
Old 03-19-2016, 07:23 AM
Toobuilder's Avatar
How about the MS21042?
http://www.aircraftspruce.com/catalo...es/ms21042.php
Edit: Sam beat me to the punch
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 03-19-2016, 07:41 AM
Vac Vac is offline
For some additional situational awareness, Van's has a notification on their website (under the support tab) regarding MS21042 all-metal lock nuts that's worth a quick read. The Special Airworthiness Information Bulletin number is HQ-14-16, dated 28 April 14.
Fly safe,
Vac
Mike Vaccaro
RV-4 2112
Niceville, Florida
Old 03-19-2016, 08:45 AM
The MS21042 spec says they can replace AN365 and a number of other nuts.
Dave
Old 03-24-2016, 04:46 AM
Default MS21042 nuts
Thanks guys. As ever, VAF is the fount of all knowledge!
Chris
Chris Mitchell
Repeat offender;
