Old 03-17-2016, 06:40 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Default Crankcase Vacuum Valves
Has anybody installed one of these crankcase vacuum valves in an O-360 engine to help keep the airplane belly clear of oil? Good, bad or indifferent?
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 03-17-2016, 07:05 AM
RVDan RVDan is offline
Search for "Anti Splat breather". There are lots of posts with important information on carbon buildup where it discharges into the exhaust.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 03-17-2016, 07:24 AM
Planecrazy232's Avatar
Planecrazy232 Planecrazy232 is offline
http://antisplataero.com/Crankcase_Vacuum_Kit_Com.html
This part would be a better option as it allows you to remove and inspect for build-ups.
Anthony
RV6-A "Aluminum Mistress"
Too many hobbies- not enough time.
2016, 2017, 2018, 2019 donor and happy to do it.
Old 03-17-2016, 07:26 AM
DanH's Avatar
DanH DanH is offline
Galin,
We've discussed them in great detail here, in multiple threads. There have been separate cautionary and technical articles in Kitplanes.
Try the search words "vacuum", "evacuator", "reed", and "NAPA 2-29000"
This one thread alone has about 300 posts:
http://www.vansairforce.com/communit...highlight=napa
A good case evacuator is beneficial. However, the exhaust tap has a cleaning requirement. Failure to keep it clean/open/clear will result in several serious problems, including blown oil seals and forced landings.
A second reed valve can be added to the system, eliminating any chance of positive crankcase pressure.
I am frankly disgusted to see Aircraft Spruce list this AntiSplat product without reference to the maintenance requirement, or the second reed valve, which AntiSplat sells as an additional kit.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-17-2016, 04:17 PM
GalinHdz's Avatar
THANKS. I guess I have a lot of reading to do.
Galin
CP-ASEL-AMEL-IR
2020 Donation made
Old 03-17-2016, 06:23 PM
JonJay's Avatar
JonJay JonJay is offline
It will take less time to clean your belly!
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-17-2016, 07:00 PM
brad walton brad walton is offline
And the plane, too.
Old 03-18-2016, 09:30 AM
JonJay's Avatar
Funny.... yes, the planes belly. There is one in every crowd.
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-18-2016, 10:11 AM
PerfTech's Avatar
PerfTech PerfTech is offline
Galin,
....We include with all systems, the secondary bypass assembly, as well as very specific maintenance instructions. The weld in tube and valve is being offered as replacement parts for existing installations, and is shipped only by us with confirmation of the install and use. Hope this helps, Allan..
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & Services
Info@AntiSplatAero.com
Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
