I am installing the GRT EFIS and eng monitor systems in my new (to me) RV6A.
Does anyone have a source for fittings to mount the oil press and fuel press senders to. They are the same senders I have seen on Dynon and MGL installations. The threads on the senders measure 27tpi.
This is the standard Van's piece, set up to accept three senders, but I cut off the top one as I only need oil pressure and fuel pressure.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020 You haven't seen a tree until you've seen its shadow from the sky -- Amelia Earhart
Thanks guys.
I had only one cylinder with egt/cht so no sensor mount. No sensors. Direct reading gauge with oil and fuel lines to the back of the inst. panel. Plane was built in '93. I just ordered the mount. that is exactly the thing.
