Old 03-14-2016, 11:02 PM
gladiator68 gladiator68 is offline
Default Light speed (or other eMag) installation?
I am working on too many things behind the panel, but realized I need to find a good spot to mount my Lightspeed box.
Welcoming any good ideas and pics you can share. Also they supply the connector with both plugs wired. Not an easy task to put thru the firewall if mounted on cool side.
Thanks for the input everyone!!
Rick Glatthaar
Olympia, WA
RV-9
Tail done, wings done,
Fuselage "almost" complete, working on wiring/panel
Sending $10 monthly in 2020.... Thanks Doug!!
Old 03-15-2016, 12:15 AM
lr172 lr172 is offline
I just mounted my EI box to the back of the stainless recess panel for the oil filter. I have reflective material on the engine side that keeps the heat down.
Larry
Old 03-15-2016, 04:09 AM
bhester's Avatar
bhester bhester is offline
Thumbs up Wire pass through
Here is how I did my wire pass through box is mounted on a fore and aft former just behind the firewall. Hope this gives you an idea. Bottom of the page.
http://http://home.newwavecomm.net/b...2012Flying.htm
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
