Dark grey grease when servicing Harzell
I was servicing my Hartzell 7666a constant speed prop today and when I removed the rear fitting and pumped aero shell 6 in the front a dark grey "grease" came out. The same happened on the other side.
Prop has 1070 hrs since new and was serviced last April with normal results. No performance issues noticed. The prop was off last year to install a new alternator belt. Has anybody seen this? Overhaul time?
Thanks in advance
Phil
Phil McCutchan
RV-8 N275RV
RV-6 N9HJ- lost to tornado
Evansville, IN
