Go Back   VAF Forums > Model Specific > RV-4
  #21
Old 03-15-2016, 07:57 PM
Steve Barnes Steve Barnes is offline
Default From the horses mouth
I called Wayne Stonesipher of Phlogiston Manufacturing a few days after the accident. He was just about ready to have a meeting with Van and told me to call him back the next day. I called him and he told me that the meeting was to adjust the production quantities on the 8 spars but not to stop production.
No modifications were to the spars and from the beginning. Van's seemed to be confident that the spars were not an issue. With thousands of those spars flying, I have not heard of another failure.
Steve
Old 03-15-2016, 07:59 PM
jrs14855 jrs14855 is offline
Default 11 G
I have to take issue with Smokey's statement about 11G's incapacitating the pilot. It's all about the duration. In high performance civilian aerobatic aircraft the duration CAN BE extremely short. In this case a 90 degree pitch change at 11 G is hardly noticeable to an experienced aerobatic pilot.
Far more important however are snap rolls. The G incurred is almost totally dependent on airspeed. The various aerobatic RV's would be very vulnerable to snap rolls entered at too high a speed. This is primarily because of the relatively low stall speed of the RV's. Also the snap roll by nature is an assymetrical maneuver, few if any engineers truly understand the forces acting on an airplane during a high speed snap roll.
A snap roll in the Pitts S1S entered at 135 statute is a 7 G maneuver. The highest G I ever incurred in the S1S was 7.5 and that was an aerobatic sequence flown in moderate to borderline severe turbulence. A typical pull at Vne is 6.5 G.
Old 03-15-2016, 08:03 PM
Default RV8
The RV8 crash was in Ripley CA, just south of Blythe. The airplane was over the aerobatic gross by approximately 90#. The elevator trim tab pushrod was disconnected at the tab.
The report does not seem to attach any importance to the tab issue.
Apples to oranges but an elevator tab actuator disconnect in the Pitts S1 will take the stick out of the pilots hands.
Old 03-15-2016, 08:13 PM
scsmith scsmith is offline
Hmmm, I didn't know about the trim tab disconnect before. This is speculation, but if that happened in flight, it could easily explain an otherwise unexplained reason for the pitch-up that caused the over-g. Its also possible that the trim clevis failed on impact and had nothing to do with the departure.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 03-15-2016, 09:01 PM
rvbuilder2002's Avatar
Anyone that has ever been involved with wreckage from a crash like this one will tell you that a lot of stuff is found disconnected.......
Scott McDaniels
Hubbard, Oregon
Old 03-15-2016, 10:04 PM
Yeah, doesn't surprise me. I've seen one. Very little was recognizable, let alone connected. Very sobering.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
Old 04-12-2016, 10:59 AM
redhawk redhawk is offline
Default Wing failure
I know there was a wing failure of a RV3 in Colorado years ago during a aerobatic maneuver. The NTSB report said something about a critical wing bolt or nut that was forgotten during assembly...
Old 04-12-2016, 03:32 PM
Christopher Murphy Christopher Murphy is offline
Default Different
The 3 has had more issues with the spar...I remember one from about 1979 or so. Pretty sure it was an assembly or modification issue.( wallowed out hole)
How many are doing snap rolls in the -4?
Cm
RV-4 "Mr. Twister"
Pitts S1S "Mexican Red" sold and missed
Mr. Twister Airshows
Rocky Mountain Renegades
the mission... have fun.
