Old 03-11-2016, 03:42 PM
airguy's Avatar
airguy airguy is offline
Default Capacitive fuel sender response with different fuels
Here is a datapoint for the group, on the differences in the capacitive sender response between fuels. I have calibrated my left tank on 100LL and the voltage ranges from 0.835 to 1.165 volts (empty to full), and when calibrated on 91 octane premium auto gas the voltage ranges from 0.801 to 1.502 (empty to full).
The capacitive sender response is significantly different, you must change the calibration sets when changing fuels if you want to trust your fuel levels.
With Dynon it is possible to have pre-loaded sets of calibration files and switch from one to the other within seconds depending on the fuel you are putting into the tanks, there is a thread discussing this on the Dynon forums. Of course, this also means you would ideally want to have your tank empty or very close to it when switching from one fuel to another.
Old 03-11-2016, 08:57 PM
Billythekid Billythekid is offline
Is this difference due to the specific gravity of the different fluids
Old 03-11-2016, 09:10 PM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
No, the dielectric constant.
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 03-12-2016, 04:59 AM
Captain_John's Avatar
Yup!
...and I can tell you that it works out to be a difference of 3 gallons with EI senders that Van sells combined with the G3X.
I calibrated for 100LL and when i was testing auto fuel, it indicated about 3 gallons more than I had on board.
Combine this with a lower BTU output of auto fuel (ie. Higher rate of consumption) and it makes for interesting test results!
CJ
The experiment works!
Old 03-12-2016, 02:27 PM
FasGlas's Avatar
FasGlas FasGlas is offline
Something new coming out from Belite. It won't change calibration for any fuel. https://jameswiebe.wordpress.com/201...ve-fuel-probe/
Old 03-12-2016, 06:30 PM
flyboy1963's Avatar
Default sounds veeeeeeeery interesting
I like the fuel trend display...kind of a visual how long you've been on that tank, if you're burning more than expected etc.
plus....
how often have I looked at the gauges, and timer, and thought,
" did I really go thru 1/4 tank in that long climb?" or was it just UNDER half before, and now it's not aQUITE at 1/4....gee, maybe I should switch tanks just to even things out!"
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 03-12-2016, 07:28 PM
I'm a bit curious about the differences in the empty readings. How can fuel type matter when empty?
Old 03-12-2016, 08:00 PM
airguy's Avatar
Valid point - it shouldn't. I'm thinking likely a variation in system voltage at the time I did one of the calibrations or something similar. I don't have an explanation for that.
Like I said, just one datapoint, insufficient background data to really make a valid discussion of it though it is an interesting datapoint.
