Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
  #161
Old 02-05-2017, 03:42 PM
rwtalbot rwtalbot is offline
Originally Posted by Toobuilder View Post
After all, the entire accessory gear train in a Lycoming depends on a single 5/16 bolt securing the crank gear- yet we don't give that much thought.
To compare the reliability of a home brewed, one of a kind crankshaft position sensor installation with a component that is the subject of numerous SBs and has 60+ years and millions of hours in service doesn't really work for me.
This whole thread started with Dan building a rear mounted pickup. Presumably he had his reasons despite both of us acknowledging the additional complexity.
We all have different views on this stuff and that's fine. My personal design goal is zero probability of a single failure taking out both ignitions.
Richard Talbot
RV-7A
Sydney, Australia
Old 02-05-2017, 05:25 PM
DanH's Avatar
DanH DanH is offline
Go for it. I can see a little higher risk per trigger, but an argument for low risk of double failure makes sense.
Dan Horton
RV-8 SS
Barrett IO-390
Old 02-08-2017, 07:30 AM
N363RV's Avatar
N363RV N363RV is offline
Default Maybe I missed it..
Maybe I missed it in an earlier post...
Dan.. I see pics in post #4..
What High voltage power pack are you using? ie. What year/model car/truck did it come from?
Did you make your spark plug wires or did you buy some off the shelf?
What spark plugs are you using? Gap?
I know you use a IO390. Do you feel that these parts would work well for an O360 lycoming? I saw that Kirk has a 360. Are you guys running the same power pack, wires and spark plugs?
Thanks.
Builders: John & Amanda
Model: RV 6A
Based - KJWY
Old 02-08-2017, 08:21 AM
DanH's Avatar
Follow the link in post#4 and read the Megajolt manuals. The popular EDIS-4 module seems to be a new or used Motorcraft DY-630, Module F1CZ-12K072-A, taken from a 91 to 96 1.9L Escort or Tracer. Also Standard Motor Products LX239.
I assume "power pack" means coils? There are two Ford choices, early and late, plus dozens of others that are compatible. Zillions of sources.
Did you make your spark plug wires or did you buy some off the shelf? What spark plugs are you using? Gap? I know you use a IO390Do you feel that these parts would work well for an O360 lycoming?
Made up plug wires. Components here: http://www.kingsborne.com/
I use long reach plugs, so they will be different. Everything else is the same.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-20-2017, 07:03 AM
DanH's Avatar
Update for those following along.
The wiring shown a few posts previously has one sneaky failure mode. If the path between the main contactor and the second battery should become open for some reason (broken wire, failed terminal, fusible link or diode burns open), the ignition would continue to operate normally...until the battery ran dead. It's not a critical failure; the other ignition would be unaffected. However, the "mag drop" is so small that a pilot might not notice. The only other clues might be a change in EGT and perhaps some slight roughness if LOP at the time.
It needs an voltage monitor, something to draw attention to a loss of alternator voltage on the second ignition. The EFIS already monitors the main bus, so that's covered. My GRT Sport doesn't have an available input for the monitor task, so I went looking for a suitable stand-alone device. This one fit the bill, and it was a whopping $4.59, delivered:
http://www.tomtop.com/modules-219/p-e1021.html
The digital display is for setting the upper and lower voltage limits, using the three buttons. It's a "set and forget"; the board is mounted in a sealed box under the panel. If line voltage goes over or under the limits, it closes the relay and sets off a buzzer. I installed a flashing LED under the #2 ign switch, and set the lower limit at 12.8V:
Function is dirt simple. The LED flashes when the ignition switch is moved to ON, prior to engine start, as battery voltage alone is below 12.8. That's the self test. It stops flashing when the alternator comes on line after start. If it flashes in flight, there is something wrong. The buzzer can't be heard in flight, but it's a perfect volume to warn that I've left the ignition on after shutdown, a nice bonus.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-20-2017, 10:30 AM
mtnclimber mtnclimber is offline
Default Thank's for that link to voltage warning board.
I've order one for the 8 and one for the 9A.
Seems like a great safety feature if using a non standard battery.
Easy to implement as adjustable over-voltage 'Crowbar' with SCR.
Roger Bloomfield
Old 08-27-2017, 05:36 PM
Chkaharyer99 Chkaharyer99 is offline
Dan,
Your diagram depicted immediately above in white over black shows a relay and a volt meter between the diode and smaller battery.
Is the relay on the blue (Tomtop) circuit board shown above the same relay as the one depicted in the white over black diagram?
Is the "voltmeter" depicted in the white over black diagram actually the LED you have mounted under the switch labeled "Mag 2"?
How's it all working? Anything you'd change or do differently.
I am preparing to install dual EI (SDS) and I'm interested in using this concept.
Thank you,
Charlie
RV-8
Old 08-27-2017, 06:48 PM
DanH's Avatar
Originally Posted by Chkaharyer99 View Post
Dan,
Thank you,
No, it's an additional check feature. You've pulled up a diagram from another thread. The voltage monitor can be seen at the lower left, parallel with IGN2. It warns if the small IGN2 battery is not being charged.
The relay, push-to-test switch, and the voltmeter (center of the diagram) allow a check of the battery itself, in flight. Pushing the button disconnects the secondary battery from the rest of the electrical system and displays its voltage under IGN2 load. The voltage monitor will light its panel LED at the same time, since the voltage will drop below 12.8V.
The inexpensive voltage monitor has been flying since early this year. I have collected the parts for the push-to-test-the-battery circuit, but have not yet installed it.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-27-2017, 07:23 PM
Thank you for the explanation. Its simple.
Charlie
RV-8
Old 08-28-2017, 03:51 PM
sblack sblack is offline
Frank there is a guy at Kars Rideau Valley Airpark (just south of Ottawa right on the Rideau River) named Jim Scoles who is running the Megajolt with a Ford EDIS module in an O-200 powered Tailwind. I'm sure if you dropped in to see him he would be happy to show it to you.
Scott Black
VAF dues 2020
Instagram @sblack2154
