Old 12-19-2006, 10:56 AM
Rick_A's Avatar
Rick_A Rick_A is offline
Default How do you store/organize your drill bits?
I would really like to improve the way I store & organize my drill bits. I've got a hodge podge of bags, plastic bins and little tubes from Avery (I like these tubes the best) and old bits strewn all over the place.
Has anyone comes up with good way to organize all the drill bits and reamers - and keep new bits separated from used ones?
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 12-19-2006, 11:43 AM
Will Womack Will Womack is offline
I have a couple of these:
Drill Index from The Yard
$6.00 per.
Will Womack
7A 72452 Wings
\_____@(")@_____/
Old 12-19-2006, 11:45 AM
Kenneth's Avatar
Kenneth Kenneth is offline
Probably not the most elegant solution, but it works for me. I just took a hunk of scrap MDF and drilled the appropriate sized holes in filled them with bits. Now the biggest problem I'm having is getting different sized bits that don't already have holes for them and now they're going to be out of order! Oh well.
Click Here
As far as used vs. new, if a bit is in used enough condition to not be considered new, it gets filed in the garbage can. I'll gladly pay for new bits rather than try to save a few dollars over the course of a project fighting with questionably sharp bits!
--Ken
Ken Monville
http://www.bandwidth.org
RV-8 - Wings, sold
RV-8 - 2nd project in planning
gpiney gpiney is offline
I use scrap packing foam. I look for sheets 1-2" thick and cut out squares of 4-6".
I then take a thick Sharpie and write the size real big on it like "40". I then punch in all my #40 bits and reamers. I do the same for 30, 12, 19, 21, 1/8" 3/16" etc. This way I can easily grab exactly what I need. As far as used bits go, I toss the dull ones.
Greg Piney
RV-8 2547
Empennage Done!
Beginning Fuselage Final Assembly!
(Tub finished, on to Landing Gear).
Old 12-19-2006, 11:51 AM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
I feel your pain... I have been wanting to do something about my bits too, but I have just been to busy (or lazy) to actually do it.
For the new bits, I just keep all them in the the little baggies they came in until I need them. The currently-in-use (used) bits then get put into an unorganized tray in my tool chest. I haven't had a problem yet, but I am always very careful about making sure I've picked up the right bit. I am sure my luck will run out some day.
For the currently-in-use bits I have been thinking of picking up an empty drill bit case from Brown Tool when I order from them next, but who knows when that will be. I am sure other vendors sell them as well, but Brown Tool came to mind.
When a bit gets to the point that I will never use it on the kit again, I just put it in a container of used-used-bits. I use them for drilling scrap, wood or whatever.
I am all ears if anybody has any suggestions.
Brad Oliver
Livermore, CA | RV-7 | SOLD
RV-7: RV7Factory.com | iPhone app list: AviatorApps.com | Photography: BradOliver.com
Old 12-19-2006, 11:53 AM
RV7Factory's Avatar
$6.00 per.
There you go! See what happens when you take too long to type a response... all these great suggestions get posted. Thanks Delmar!
Brad Oliver
Old 12-19-2006, 11:54 AM
Dayton Murdock's Avatar
Dayton Murdock Dayton Murdock is offline
Default Machinist
I throw them all in a box.
Dayton Murdock
VAF#408 RV4 N359DM Flying 1046 hrs 7/16/19
Builder Log
Old 12-19-2006, 11:59 AM
grjtucson's Avatar
grjtucson grjtucson is offline
Default Funny You Should Ask
Funny you should ask about this, I just conjured this solution up to the same problem you're facing, and there is not much in my shop that I am prouder of at the moment (I am SUCH a dork).
I had a lot of different sizes, with only one or two of each. Lots of 6" bits plus lots of threaded ones in short, medium, and long. I wanted easy access, expandability, and it had to be cheap.
The shelves I made from scrap lumber, and I bought 100 boxes from PaperMart online.
They're 6-1/2 X 1-3/8 X 7/8 WHITE SWIRL SILVERWARE BOX, #451061, $33.00 CASE + Freight $8.69. They come with foam in them (toss) and the tops are a bit deeper than the bottoms. I still have probably 30 tops and 100 bottoms if you'd like some, contact me.
The top shelves have some sizing guides, unibits, and other packaged sets. You can probably see I've got multiple boxes for 1/4". All the bits, as well as threaded bits, countersinks, reamers, and deburrers fit great, but when they don't, or when you want to keep new from used, or reamers separate, just add a box. Also, as I add new sizes, there's plenty of room to grow.
Hope this helps.
George
George Jenson - http://www.georgejenson.com
Tucson, AZ - RV-7 Standard Build
Empennage Completed 1/06, Wings Completed 11/06, Fuselage Done 9/08, Panel Wiring Done 7/19. About to haul it to the airport.
Old 12-19-2006, 12:06 PM
FredMagare FredMagare is offline
Send them to me! My Drill Doctor will make them like NEW!
Fred
magaref "@" hayscisd.net
Old 12-19-2006, 12:11 PM
RV7Factory's Avatar
George.... we're not worthy!!! Great stuff!!!
Brad Oliver
