Corrosion-X Applicator
I've had difficulty applying Corrosion-X down the RV12 elevator balance arm tube because of a bolt that passes through the diameter of the tube. I went to a local gun shop and purchased the gun bore cleaning tool below with extensions. Just fold and attach a gun cleaning paper patch (not in photo) to the applicator end of the tool, spray the paper with Corrosion-X then swab the interior of the balance arm or torque tube. It works great.
[IMG]  [/IMG]
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered (Sold)
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
