I use steel fittings on the engine and a steel fitting on the firewall for the fuel bulkhead fitting.
This spring I replaced my aluminum fittings on my oil cooler with steel. A friend had one crack on his oil cooler.
While the engine was off for a rebuild I ordered all new hoses from Tom at
http://www.tsflightlines.com/
My hoses were ten years old and it seemed an excellent time to replace them.
Tom provided excellent fast service and they all fit perfectly. I found the prices to be less, even with the exchange, then I could have sourced locally.
DO not use automotive parts or fittings, even if they are called "AN". Quality aircraft hoses are cheap cheap insurance, do NOT skimp on hoses.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race,
average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
