I have made some very tight bends with sugar. Get an extra long length of tube flared on both ends with nuts. seal one end with an AN plug of the appropriate size and pack the tube with sugar. Add another plug on the open end and be sure the sugar is tightly packed when the plug tightens down. Now you have a solid "rod" which will not colapse under even a very tight bend. Once to shape, dump out the sugar and wash in hot water. The sugar will not scratch the inside of the tube and hot water will disolve any remaining sugar.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
