Old 03-04-2016, 08:59 AM
dent dent is offline
Default bellcrank jig device
I just got a 4 project and do not have any pictures of information on the bellcrank jig device.
Any help would be appreciated.
Dennis
Old 03-04-2016, 09:19 AM
rvbuilder2002's Avatar
There is no bellcrank jig for the RV-4.
The drawings have a dimension detail showing what the neutral position is.
Scott McDaniels
Hubbard, Oregon
Old 03-04-2016, 08:51 PM
thank you for your information.
Old 03-04-2016, 09:32 PM
HFS HFS is offline
Default In the "old days" ...
we just set up the "call out" posit in the drawings and then drilled a #41 hole through the bellcrank support bracket and the bellcrank and used an .089" dia hinge pin section to connect them when needed. I always drilled mine so they would be accessible through the inspection cover later - if ever needed after the aircraft was flying.
David Howe
