Old 03-03-2016, 03:46 PM
Tumper's Avatar
Tumper Tumper is offline
Default Note to quick build wing...builders
To the builders out there that are utilizing quick build wings, let me offer you some advice. Prior to installing the access cover and sealing up the wing, take a second and check the vent line fitting inside the wing near the root rib. You can reach your hand in the access cover opening and put a wrench on the fitting and just check to make sure those quick build friends tightened it up.
It sure is easy to do prior to prosealing that cover on, and mounting the wing on your bird.
Don?t ask me why I post this. But I can tell you how to know if your vent line is loose inside the tank.
Just saying?
Dean Eiland
Aubrey, TX
Former Vice President EAA Chapter 1246
RV-9 (yes) N369RV
Mattituck IO-360, C/S Whirl Wind Prop, GRT, Digiflight II, Garmin SL30 & GTX 330 and Hotel Whisky Aux tanks, Bla Bla Bla
Flying
Old 03-03-2016, 10:27 PM
edneff's Avatar
edneff edneff is offline
Amen.
See this thread, and my posts, last one being #82
I bought this aircraft with 180 hours on it and ended up having to replace the vent line in one tank, although it was NOT a QB.
http://www.vansairforce.com/communit...t=81517&page=9
Ed Neffinger
KCCR
RV7a
RV7
RV8
ATP, CFIA, II, ME, G
Old 03-04-2016, 11:00 AM
Breezy Breezy is offline
Dean,
This is a good heads up.
This past summer an owner dropped off his Quick Build RV-8 for a condition inspection. He mentioned that one tank was venting puddles of fuel on the hangar floor. I pushed a hose over the belly vent and blew into it while holding a finger over the tube near the filler neck. I could hear bubbling in the tank.
After removing the tank and access panel I found the flare nut at the bulkhead fitting was sliding freely on the tube.
The aircraft is 6-7 years old so I figure the nut was only finger tight and vibrated loose.
Breezy
First offense RV-8; N594WR; 80594 (time served)
ECI TITAN IOX 360 A1A9N, G3X
Repeat Offender: 83137 (Flying 10/16)
N837DW; Superior IO 360; G3X Touch.
Exceptional Aircraft Award, Sun N Fun 2017; Best Homebuilt, Mid-Eastern Regional Fly-in 2017.
One More Time: 140359, -14 in process, IO-390 (Maybe)
KHAO (Hogan Field)
