  #11
Old 12-25-2006, 12:07 PM
Ironflight's Avatar
VAF Moderator / Line Boy
So far, I have done a little web shopping for the necessary parts, but haven't found a supplier cheaper than what Creativair is selling. I have to use the 2" light package for my installation, and have been considering it....just haven't decided to spend the money. If anyone finds a source for the bulbs and little power supplies cheaper than Creativair, I'm all ears....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-25-2006, 12:25 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Originally Posted by aadamson
Sure ya can wig-wag em... Check out www.creativair.com and the setup he offers and the wig-wag option.
OK. That bit of info just cost me $477 - now I need to buy the HIDs!
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 12-25-2006, 07:06 PM
N130WN's Avatar
N130WN N130WN is offline
Default HID in the tip?
Are the HID options out there strictly for the leading edge installation, or will they fit in the wing tips? I have the traditional duckworks setup on the RV-8 and they work fine, but I may pursue a wingtip option on the RV-7....
Larry Bowen
RV-8 Built, sold, missed.
RV-7 Built, sold, missed.
RV-8 Emp in progress ...
RV-8A Purchased, flying.
Old 12-25-2006, 07:31 PM
bullojm1's Avatar
bullojm1 bullojm1 is offline
If you go with the duckworks kit, then HIDs are a choice for the leading edge. CreativAir.com has HID's for the wingtips for the new RV7/8 wingtips.
Mike Bullock
RV-7, Flying!
http://www.rvplane.com
EAA Technical Counselor
Old 12-30-2006, 12:45 PM
Gsuit's Avatar
Gsuit Gsuit is offline
Has anyone ever put HID landing lights into the older "bat" style wing tips (W-715)?
Clayton Henderson
Beaumont, TX
RV-7 N454CH (Flying)
Old 12-30-2006, 01:11 PM
Ironflight's Avatar
Default Not Yet, but....
Hi Clayton - I have the Bat Wing tips, and installed the Creativair landing light kit (before the HID's were available). The problem, of course, is that you have to use 2" lights. Creativair now has a 2" HID kit, and I am considering installing them....just haven't added up all of the Christmas bills yet!
If someone else does it first, I hope to get a report.
Paul
Paul F. Dye
Old 12-30-2006, 02:20 PM
svanarts svanarts is offline
Originally Posted by petehowell
If you like the geeky stuff this is pretty cool.
LED for Forward Lighting
I bought a set of what was advertised as LED fog lights thinking that if a guy could adapt a fog light system to be aircraft landing lights, then a guy could adapt LED fog lights to be aircraft landing lights. I thought wrong. Nowhere near bright enough.
I think in 5 years or so there will be readily available automotive LED headlight system. From what I've read though, the power consumption of LED headlights will be very nearly the same as traditional lighting methods.
Scott VanArtsdalen
www.airprayer.net
