Mixture Cable F/W Pentration for Vertical Induction
I am converting my O-360 to vertical FI (Bendix RSA). I will be using the VA-182 bracket and will clearly need to move my Mixture Cable penetration up quite a bit to get the right angle and gain some length. The carb config has it very low and pointing up.
I wouldn't expect Van's to have a firewall layout, as they don't seem to support the vertical induction configuration. I was hoping that someone could share where they placed their cable penetration that allowed them to use the standard mixture cable. It appears that I will have enough length if I move it up several inches from the current location low on the firewall.
Larry
