Paul:
The answer is in the archives. I do not now how to link to the article so will paste it here. I am in agreement with George.
I desire a SYSTEM approach to ignition. As much parts interchangablity as possible. It is just as much work to retrofit one EI in to a dual mag system as it is to redo with dual EI.
With a little engine, I want the extra 1% that dual EI system gives me.
-------- insert --------
Don't mix and match EI brands
Originally Posted by
Highflight
There 'ya go then.
Go with a Lightspeed on one side and mag on the other for now. Then later when the P-mags are tested and ready, replace the mag with the P-mag and get the best of both worlds.VernRV7-A
Actually you get the worst. With matched L&R ignition you will get better performance. IF you mix and match electronic ignition you are negating the advantage of having dual electronic ignition. There is no way two different EI brand ignitions will fire at the same time consistantly. Most advantage of EI is from the first one. The extra 1% of performance/efficency with the second EI, is only if it works together, at the (same time) with the other ignition. You might as well go one EI and a mag if you are not going to have matched EI. I asked E-mag/P-mag folks about going (1) LS and (1) P-mag, they did not recommend it, but to their credit they suggested going dual LS would better or Dual E/P-mag. They had nothing negative to say about LS. There are advantages to both. BTW Jeff Rose's ignition was out of production for a while but is now available again as electoair:
http://www.electroair.net/
Cheers George
-------- end insert ---------
