Go Back   VAF Forums > Model Specific > RV-3
Old 02-29-2016, 06:52 PM
flyenforfun's Avatar
flyenforfun flyenforfun is offline
Default Thinking of building an RV-3
I built in RV8 and completed in 2012 it now how has about 350 hours on it. I always liked the RV 3 my goal would be to build it as cheap as possible using steam gauges no electrical system and a used motor and get it done within two years. The only thing that is intimidating is that the fuselage in the tail section are not pre-drilled so my question is this: do I have to locate and drill all the holes or do they provide occasional pilot holes to give you somewhere to start.
Matt Giordano Sr. and Jr.
RV-8 - N861MM
Wilmington, DE
Old 02-29-2016, 07:02 PM
Ha! Prepunched holes? Pilot holes? On my kit, they were limited to the elevator bellcrank, the wing's access panels and the major holes in the F-303 bulkhead. And the spar - the spar like the RV-8 spar came pre-made. And that was it, about a dozen parts with holes.
Anything else, ribs, rear spar, empennage, skins, bulkheads, you get to drill a hole wherever you want to.
If you haven't read it already take a look at my blog here on VAF.
Dave
RV-3B
Old 02-29-2016, 07:03 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Mark and drill ?
You have to fit , mark, drill and dimple/ countersink everything. Not hard, you just have to think ahead and do the work. That said, Dan at Panther told me the -3 is lighter than Panther although Panther is easier to build. It appears general concensous is the -3 is still the altimate flying machine. There is a complate 3A available with no engine for 12,500.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 02-29-2016, 09:09 PM
Saber25's Avatar
Saber25 Saber25 is offline
"do I have to locate and drill all the holes or do they provide occasional pilot holes to give you somewhere to start", Most if not all of the holes will be drilled by the builder and then some :-).
Best of luck
Build 'em light, keep it simple
I'd rather fly than tinker.
"There's a big difference between a pilot and an aviator. One is a technician, the other is an artist in love with flight."
- Elrey B. Jeppesen,
Old 03-01-2016, 08:55 AM
KatieB's Avatar
KatieB KatieB is offline
No holes are punched because you need to trim or flute or tweak all the parts and skins to final shape before you assemble them together. It's not difficult, but you do spend a lot of time studying plans, studying parts (because you can't blindly follow the plans or some things won't fit), and thinking about what you need to do before you put a drill to it. And you'll spend time building jigs. Contrast that to the 8 where you mostly cleco the thing together out of the box. My hubby tortured me with that many times when he built his 8 tail kit and his Panther. "Look what I made! A Vertical Stab in a Weekend! What? Yours took 4 months? You're slow." Aaargh...
Katie Bosman
RV-3B sold, but flying!
Next project: ???
Builders gonna build...
Old 03-01-2016, 01:13 PM
dlomheim dlomheim is offline
Default RV-3 Build
Originally Posted by flyenforfun View Post
I built in RV8 and completed in 2012...The only thing that is intimidating is that the fuselage in the tail section are not pre-drilled so my question is this: do I have to locate and drill all the holes or do they provide occasional pilot holes to give you somewhere to start.
As mentioned so far regarding drilling all the holes...yes. I restored an RV-3A after building an RV-9A to the FWF / glue the plexiglass is all that is left phase. When I went through the 3A, I found the original builder had done a poor job on the vertical stabilizer and it had multiple cracks that had been stop drill and covered with a doubler. I therefore spent the $70 or so for the metal from Van's and proceeded to redo it. From what I had already learned building my 9A, building the vertical stab gig and doing it was very doable, but quite a bit more time consuming compared to the "pre-drilled" kits! The vertical stab. took about 35 hours to build, to include the gig, laying out the parts and riveting it all together. With what you know from building the "8", the project will be very doable. I loved flying my 3A and it was fairly light with an old O-290 "G" modified as a pseudo "D". Good times!
Doug Lomheim
RV-3A sold
RV-9A Mazda 13B / FWF
Old 03-05-2016, 06:58 PM
RV3bpilot's Avatar
RV3bpilot RV3bpilot is offline
The 3 fuselage is not that bad. Just mark the holes and then strap the skin over the skeleton and drill from the inside out and cleco as you go...
Robin Mckee
New Ulm, MN 56073
RV3b N219BB
420 hours and counting
Old 03-06-2016, 02:32 PM
chris mitchell chris mitchell is offline
If it's like the RV-4, there is no predrilling anywhere. The plans and instructions are, um, primitive and replete with contradictions and errors. Building a predrilled kit like an -8 is a doddle. Not so much building as assembling. The legacy kits - 3,4 and 6 are more challenging and fun, but don't underestimate them.
I think that the RV-3 has QB wings as an option. Makes life easier but more expensive!
Chris
Chris Mitchell
Repeat offender;
RV-8, QB, built, flown 150 hours, sold;
RV-4 - attempted repair, rebuild and remediation - abandoned and junked ;
RV-4 fuselage and wing kits - both at QB stage;
2015-2018 dues paid!
Old 03-06-2016, 03:51 PM
Yes, QB wings are available. Having built the standard-build wings, I'd recommend the QB ones.
Dave
Old 03-06-2016, 06:41 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Dave
We did the QB wings, and yes, well worth it if you want to save some time - but beware, they don't mass assemble them, they are built to order (I suspect), and we foudn a few errors when measuring for a few items. All part of the fun of building a -3, and yes - I really enjoyed it!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
