02-27-2016, 02:47 PM
MINIMUM Coax Length for GPS Antennas on 650 and 430?
I am installing a GTN 650 and a GTS 430 -- I thought I had heard there is a MINIMUM coax length (RG400) for the GPS antennas---- I need to order the coax --- anyone have the information?
Thanks for the help,
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
02-27-2016, 03:04 PM
You'll probably need the manual to install it too. But 6.5' to 35' of RG142/RG400 will do the trick. (1.5-6.5db loss).
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
02-27-2016, 03:26 PM
Walt --- thanks much!!
I knew VAF would come through! --- I have the manuals, but could not find a specific length.
Much appreciated!
Ron
02-27-2016, 04:30 PM
Why is there a minimum length? This makes not sense.
Carl
02-27-2016, 04:45 PM
Minimum coax length
Is specified in the install manual. According to the upgrade installation manual for the 400 W/500 W series, the GPS antenna coaxial cable must have a minimum of two shields (that is RG 400 or RG 142B). The minimum length is approximately 13 feet of RG 400, producing a loss of 3dB. It's a lot of coax! Adding any connectors or adapters (eg BNC to TNC) increases the loss so you could use less coax. The required loss ranges from 3 to 7 dB according to the manual (see 2.5.4 and 3.10.1).
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
02-27-2016, 08:33 PM
Carl
Reason, in English: Garmin made the receiver as sensitive as they could, a worthy design goal. But the antennas are mostly from non-Garmin OEM's, and some have more gain than anticipated. The extra signal strength can cause the receiver to not meet all the TSO specs, like overload, rejection of other signals, etc. Rather than re-designing the receiver to have lower sensitvity, it is easier to just insert some loss - coax, attenuator, etc.
