Whether you have the position senser installed to show full up when in or out will affect the display, as well. Just mount them in and turn it upsidedown if it registers the wrong way. Leave a little slack in the wires so you can pull it out and turn it. Another option is to change the wires to reverse the display. Ray Allen can advise you on that. Before you bundle all the wires up, try a test run of all your electrical devices.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
